New to coding (<2 weeks). I have set up this code to take the joystick inputs, run tests against data, and output speeds for 4 different "motors" into the serial monitor. Values for the joystick change when the joysticks are moved, but the "motor speeds" do not change.
I don't believe I am caught in an infinite loop because the joystick values change in the serial monitor.
Maybe i am not using the proper loop type to test the joystick values?
Any help is much appreciated!
Joystick_Drone.ino (3.1 KB)
