Joystick,xbee, sabertooth program help questions.
I am having trouble getting this code to run properly. It kinda works. When the xbees connects the wheels go toward but wont go in reverse. What they wii reverse for a turn though
My fist question is can a transmitted Byte be a negative number?? Or am i understand the byte description wrong? Does it have to be a integer??
The whole story.
Have joystick connected to a Arduino UNO sending the data using an XBEE.
The robot has a Arduino with an XBee receiving the data then sending it to the Saber-tooth 2X35 using software serial and Packet serial on the Saber-tooth motor controller.
I can see the data being received by the robot arduino using serial monitor.
My question is. Line 52 to 54 is maping the data to -126 to +126 which the Saber tooth want to see. ( I think)
// The switch is towards the joystick (full speed)
tempFB = map(FB, 0, 1024, -126, 126);
tempLR = map(LR, 0, 1024, -126, 126);
But then on line 66-69 its shifting the data to 0 to +255 and i don’t understand why.
// Shift analog data up so we have a range of
// 0-255
tempFB = tempFB + 127;
tempLR = tempLR + 127;
On line 74-76 it assembles the packet (BYTE) to be sent to the Saber-tooth.
So is the Byte a negative number? Does Arduino serial monitor display a Negative number?
So the data being sent to the Saber-tooth is 0 to +255. Which i believe is incorrect for Packet serial.
// Analog Input Variables
int FB;     // Forward and Back
int LR;     // Left and Right
int Spin;   // Rotation (used on vectoring robots)
// Temporary variables used in calculations
double tempFB, tempLR, tempSpin;
// Transmitted packet
byte byteFB;
byte byteLR;
byte Digital1;
byte checksum;
// Reverse bits
bool revA0 = 1;  // These are used to easily flip
bool revA1 = 0;  // the direction of the joystick
// Misc variables
int deadband = 5;
  Serial.begin(9600);   // COM to xBee
  reinitVars();    // nulls out temporary variables
  captureData();  // retrieves new data
  packetizeData();  // assembles data to be sent
  transmitData();       // send data off to xBee
  //debugData();        // print out formatted debug data
  delay(20);  // Delay needed for consistant communication
// Reinitialize temporary variables
void reinitVars() {
  Digital1 = 0;
  tempFB = 0;
  tempLR = 0;
// Retrieve analog input data and conform to specs
void captureData() {
  FB = analogRead(A0);
  LR = analogRead(A1);
  // Reverse input analogs if flagged
  if (revA0)  { FB = 1024 - FB; }
  if (revA1)  { LR = 1024 - LR; }
  if ((tempFB > (0 - deadband)) && (tempFB < deadband) )
  { tempFB = 0; }
  if ((tempLR > (0 - deadband)) && (tempLR < deadband) )
  { tempLR = 0; }
// Assembles data to be sent
void packetizeData() {
  // 0-255
  // Assemble the digital packet
  // Add status of switches to digital1 here
  // convert transmitted data to bytes
  byteFB = byte(tempFB);
  byteLR = byte(tempLR);
  // calculate checksum
  checksum = byteFB + byteLR + byte(Digital1);
// xBee Communication
void transmitData() {
  Serial.write("S");
  Serial.write("D");
  Serial.write("R");
  Serial.write(byteFB);
  Serial.write(byteLR);
  Serial.write(byte(Digital1));
  Serial.write(checksum);
// Print out values for easy debugging
void debugData() {
  Serial.print("[FB: ");  Serial.print(byteFB, HEX);          Serial.print("]");
  Serial.print("[LR: ");  Serial.print(byteLR, HEX);          Serial.print("]");
  Serial.print("[D1: ");  Serial.print(byte(Digital1), BIN);  Serial.print("]");
  Serial.println("");
