JS40F Movement Sensor Broken
Hello, we are building a mini sumo project with arduino nano but despite the correctness of wiring, we can't get a JS40F movement sensor working. It used to work neatly but now outputs the same value although we move the vehicle. No change in code nor the wiring. We used a different JS40F but situation is the same, it worked for a while then stopped. What can be the cause?
cristal ball is not available at the moment... do yourself a favour and please read How to get the best out of this forum and provide all the necessary documentation for your ask.
you are possibly using the component outside specs and after a while you fry it.... just a guess
Might be a faulty batch of components or bad clones
Might be a bug in your wiring or code
