JSN-SR04T R19 Resitor Values ?
I can not find the value of R19 resistor to change the working mode of this sensor.
Can someone point me do a document where i can find these values please
Best regards,
Fabrizio
The JSN-SR40T datasheet tells you how to adjust R27 to change modes.
No mention is made of R19.
On my board it says R19.
Location is in the same area, R19 resistor orientation is horizontal.
Title of post is wrong, it should be AJ-SR04M, printed on the PCB, i corrected it.
I will try the resistor values specified in the datasheet .
Thanks you for datasheet
Regards,
Fabrizio
Here is the correct datasheet in case someone is searching for it.
Sensor is ok until 1200mm
For further distances he is way off.
