JSON and MQTT
Im trying to send a JSON doc from an UNO to ESP over serial and then publish it over MQTT.
I am having trouble with storing the JSON doc serial message as a character array to then publish.
UNO code
#include <ArduinoJson.h>
#include <DHT.h>
#define DHTPIN 4 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22  (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
String message = "";
bool messageReady = false;
  dht.begin();
  // Monitor serial communication
  while(Serial.available()) {
    message = Serial.readString();
    messageReady = true;
  // Only process message if there's one
  if(messageReady) {
    // The only messages we'll parse will be formatted in JSON
    DynamicJsonDocument doc(1024); // ArduinoJson version 6+
    // Attempt to deserialize the message
    DeserializationError error = deserializeJson(doc,message);
    if(error) {
      Serial.print(F("deserializeJson() failed: "));
      Serial.println(error.c_str());
      return;
    if(doc["type"] == "request") {
      doc["type"] = "response";
      // Get data from analog sensors
      doc["Humidity"] = dht.readHumidity();
      doc["Temperature"] = dht.readTemperature();
      serializeJson(doc,Serial);
ESP code
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "";
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE  (50)
char msg[MSG_BUFFER_SIZE];
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '1') {
    digitalWrite(BUILTIN_LED, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is active low on the ESP-01)
    digitalWrite(BUILTIN_LED, HIGH);  // Turn the LED off by making the voltage HIGH
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("Topic", "hello world");
      // ... and resubscribe
      client.subscribe("Topic");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  pinMode(BUILTIN_LED, OUTPUT);     // Initialize the BUILTIN_LED pin as an output
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  client.loop();
  unsigned long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
    handleIndex();
void handleIndex()
  // Send a JSON-formatted request with key "type" and value "request"
  // then parse the JSON-formatted response with keys "gas" and "distance"
  double  Temperature = 0, Humidity = 0;
  // Sending the request
  doc["type"] = "request";
  serializeJson(doc, Serial);
  ////////////////////////THIS PART HERE/////////////////////
  // Reading the response
  boolean messageReady = false;
  while (messageReady == false) { // blocking but that's ok
    if (Serial.available()) {
  char buffer[256];
  serializeJson(doc, buffer);
  if (client.publish("Topic", buffer)) {
    Serial.println("Publish ok");
  else {
    Serial.println("Publish failed");
Update:
i added lines to ESP code to try and convert string to char array
  char buffer[256];
  message.toCharArray(buffer, 256);
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
  Serial.print("] ");
void reconnect() {
      client.subscribe("PCTopic");
      delay(5000);
  setup_wifi();
    reconnect();
  client.loop();
    lastMsg = now;
    handleIndex();
void handleIndex()
  char buffer[256];
  else {
This is what i get from the MQTT server
{"type":"request"}Publish ok
The serial monitor on the UNO
deserializeJson() failed: InvalidInput
{"⸮ ":null,"Humidity":51.8,"Temperature":24.1}deserializeJson() failed: InvalidInput
{"⸮ ":null,"Humidity":50.8,"Temperature":24}deserializeJson() failed: InvalidInput
Update:
ESP
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
  Serial.print("] ");
void reconnect() {
      delay(5000);
  setup_wifi();
    reconnect();
  client.loop();
    lastMsg = now;
    handleIndex();
void handleIndex()
  client.publish("Topic", message.c_str());
MQTT Server
{"W":null,"Humidity":51.4,"Temperature":24}
{"W":null,"Humidity":50.8,"Temperature":24}
Why am i getting "W":null?
