json parsing working alone and not with another code
i have some ino file that only do the json parsing of the same json response from the same weather service and it’s working well here is the code. i am using nano v3 with esp8266 wifi
#include <ArduinoJson.h>
#include "WiFiEsp.h"
#include <SPI.h>
WiFiEspClient client;
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
// Name address for Open Weather Map API
const char* server = "api.openweathermap.org";
const unsigned long HTTP_TIMEOUT = 10000;  // max respone time from server
const size_t MAX_CONTENT_SIZE = 512;       // max size of the HTTP response
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
int status = WL_IDLE_STATUS;
// The type of data that we want to extract from the page
struct clientData {
  char temp[8];
 // char humidity[8];
// ARDUINO entry point #1: runs once when you press reset or power the board
  // initialize serial for ESP module
  Serial1.begin(9600);
  // initialize ESP module
  WiFi.init(&Serial1);
 if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println(F("WiFi shield not present"));
    // don't continue
    while (true);
  while (status != WL_CONNECTED) {
    status = WiFi.begin(ssid, pass);
// ARDUINO entry point #2: runs over and over again forever
  if(connect(server)) {
    if(sendRequest(server, resource) && skipResponseHeaders()) {
      clientData clientData;
      if(readReponseContent(&clientData)) {
        printclientData(&clientData);
  disconnect();
  wait();
// Open connection to the HTTP server
bool connect(const char* hostName) {
  Serial.print("Connect to ");
  Serial.println(hostName);
  bool ok = client.connect(hostName, 80);
  Serial.println(ok ? "Connected" : "Connection Failed!");
  return ok;
// Send the HTTP GET request to the server
bool sendRequest(const char* host, const char* resource) {
  Serial.print("GET ");
  Serial.println(resource);
  client.print(F("GET /data/2.5/weather?q=xxxxxx,xxxxxx&units=metric&APPID=xxxxxxxx&type=accurate"));
  client.println(F(" HTTP/1.1"));
  client.print(F("Host: "));
  client.println(host);
  client.println(F("Connection: close"));
  client.println();
  return true;
// Skip HTTP headers so that we are at the beginning of the response's body
bool skipResponseHeaders() {
  // HTTP headers end with an empty line
  char endOfHeaders[] = "\r\n\r\n";
  client.setTimeout(HTTP_TIMEOUT);
  bool ok = client.find(endOfHeaders);
  if (!ok) {
    Serial.println("No response or invalid response!");
  return ok;
// Parse the JSON from the input string and extract the interesting values
// Here is the JSON we need to parse
bool readReponseContent(struct clientData* clientData) {
  // Compute optimal size of the JSON buffer according to what we need to parse.
  // See https://bblanchon.github.io/ArduinoJson/assistant/
  const size_t bufferSize = JSON_ARRAY_SIZE(1) + JSON_OBJECT_SIZE(1) +
      2*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(4) + JSON_OBJECT_SIZE(5) +
      JSON_OBJECT_SIZE(6) + JSON_OBJECT_SIZE(12) + 390;
  DynamicJsonBuffer jsonBuffer(bufferSize);
  JsonObject& root = jsonBuffer.parseObject(client);
  if (!root.success()) {
    Serial.println("JSON parsing failed!");
    return false;
  // Here were copy the strings we're interested in using to your struct data
  strcpy(clientData->temp, root["main"]["temp"]);
 // strcpy(clientData->humidity, root["main"]["humidity"]);
  // It's not mandatory to make a copy, you could just use the pointers
  // Since, they are pointing inside the "content" buffer, so you need to make
  // sure it's still in memory when you read the string
  return true;
// Print the data extracted from the JSON
void printclientData(const struct clientData* clientData) {
  Serial.print("Temp = ");
  Serial.println(clientData->temp);
 // Serial.print("Humidity = ");
 // Serial.println(clientData->humidity);
// Close the connection with the HTTP server
void disconnect() {
  Serial.println("Disconnect");
  client.stop();
// Pause for a 1 minute
void wait() {
  Serial.println("Wait 60 seconds");
  delay(60000);
but when i add it with more code it doesnt work anymore and always giving me parsing failed here is the code of the other project which i have it in a function that is triggered by timer from time to time:
void getTemp(){
char serverName[] = "api.openweathermap.org";
t1.stop(tim);
client2.stop();
 if(client3.connect(serverName, 80)) {
    if(sendRequest(serverName) && skipResponseHeaders()) {
 client3.stop();
  tim = t1.every(10000, getTime);
bool sendRequest(const char* host) {
  client3.print(F("GET /data/2.5/weather?q=xxxxxx,xxxxx&units=metric&APPID=xxxxx&type=accurate"));
  client3.println(F(" HTTP/1.1"));
  client3.print(F("Host: "));
  client3.println(host);
  client3.println(F("Connection: close"));
  client3.println();
  return true;
  client3.setTimeout(HTTP_TIMEOUT);
  bool ok = client3.find(endOfHeaders);
  return ok;
  const size_t bufferSize = JSON_ARRAY_SIZE(1) + JSON_OBJECT_SIZE(1) + 2*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(4) + JSON_OBJECT_SIZE(5) + JSON_OBJECT_SIZE(6) + JSON_OBJECT_SIZE(12) + 390;
  JsonObject& root = jsonBuffer.parseObject(client3);
    Serial.println(F("JSON parsing failed!"));
    return false;
  return true;
  Serial.print(F("Temp = "));
  //Serial.print(F("Humidity = "));
  //Serial.println(clientData->humidity);
Actually the first code works when its alone but second doesn’t and yes it retrieve the json as i tried to print out the response and all is grabbed well but the problem is the parsing itself and always gives me parsing failed. i am sure you are going to tell me that maybe the memory issue is the problem which i dont think so but not sure.
yes the first code has
Sketch uses 14890 bytes (48%) of program storage space. Maximum is 30720 bytes.
Global variables use 870 bytes (42%) of dynamic memory, leaving 1178 bytes for local variables. Maximum is 2048 bytes.
and the second has lower memo which is
Sketch uses 29106 bytes (94%) of program storage space. Maximum is 30720 bytes.
Global variables use 1339 bytes (65%) of dynamic memory, leaving 709 bytes for local variables. Maximum is 2048 bytes.
but actually the assistant of the jsonarduino lib calculated that i only need AVR 8-bit 697
which is less than the 709 i have of ram. not sure as i mentioned above but here to get more info about this situation/issue.
one more question can i use json-streaming-parser with nano v3 connected to esp? or just work directly with the esp only?
thanks alot,
Max
bump
I'm quite sure that you're running out of memory. Every single variable used in a function needs memory when the function is called. When you nest functions, you need to add it all up. Function calling might also add some bytes.
You have only 12 bytes left and that is simply not enough.
First step would be to move all fixed strings to PROGMEM; that will basically free RAM at the expense of flash memory.
And you might be better of looking for another model with more ram.
By the way, give your thread time to go around the world; those that really can advise might be sleeping at the moment.
And kicking a thread within 24 hours is considered impolite by many.
i guess i need more ram model and you are right man.
Maxwell,
I've copied your code to my ide and verified it. But it give me this error message:
Any ideas? I'm looking to get this working as i'm working on a weather project for the wife. Thanks..
Arduino: 1.8.8 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Martin Gundel\Documents\Arduino\sketch_feb25b\sketch_feb25b.ino: In function 'void loop()':
sketch_feb25b:52:28: error: 'resource' was not declared in this scope
exit status 1 'resource' was not declared in this scope
