Hi there,
I there. I have installed the Json WifiManager. My Problem is this:
Allways when the Wifi-Router (my Samsung Phone) disapears for a while, than the code (and I suppose also the CPU) slows deep deep down. It slows down because the ESP is allways trying to reconnect to the router. And this is a problem for me (the slowing down).
I also made a counter which counts if there is no connection.. if the counter reaches for example 3000 (3 Seconds) than it disconnects via
WiFi.disconnect();
and than I have put a second counter, which counts up until 30000 (30 Seconds), and than I manually let it reconnect via:
if(SPIFFS.exists("/config.json")){
const char * _ssid = "", *_pass = "";
File configFile = SPIFFS.open("/config.json", "r");
if(configFile){
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
configFile.close();
DynamicJsonDocument jsonBuffer(1024);
DeserializationError error = deserializeJson(jsonBuffer, buf.get());
if(error)
return ;
_ssid = jsonBuffer["ssid"];
_pass = jsonBuffer["password"];
WiFi.begin(_ssid, _pass);
But if there is still no Wifi router nearby, than suddenly the config.json disapears completely... as if someone has deleted it.
My questions to you is: are the better alternatives to Json Wifimanager which makes no problems at all ?
