Hi
I "think" i got a zip file made for 1.6.8 and also the JSON needed
I can download and extract the zip with no issue... and its also the download version i got the checksum from
any clue why its keeps on saying CRC mismatch?
Hi
To make it clear... this is so i from boards manager can install my board
just checked again this morning that the checksum in the JSON is correct
i do so by first uploading the zip.... then downloading it again and make sure i can extract it. then i get the checksum from it and make sure it's correct in the JSON
for some obscure reason the IDE says
CRC doesn't match. File is corrupted.
java.lang.RuntimeException: java.lang.Exception: CRC doesn't match. File is corrupted.
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$20(ContributionManagerUI.java:176)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.Exception: CRC doesn't match. File is corrupted.
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:77)
at cc.arduino.contributions.packages.ContributionInstaller.install(ContributionInstaller.java:103)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$20(ContributionManagerUI.java:173)
... 1 more
i managed to get it half working...
it will show up in board manager and i can click install
BUT...
Version info is not shown in board manger
It's not marked as installed
if i install it will say file is allready there, so it does extract it on the first try
Figured it
in the JSON there was omc in small letters... i changed it to capitals like in the rest of the file and it works
