json
I am making a project that uses json to send data from Serial to webpage but it doesent work.
code:
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
#include <ESP8266HTTPClient.h>
#include <Arduino.h>
const char* ssid = "Test net";
const char* password = "Abc112233Abc";
//OTA_setup
const int OTA_port = 8266;
const char* OTA_password = "admin";
//OTA_setup
//OTA
bool OTA_update = false;
uint16_t OTA_time = 0;
//OTA
//JSON_board
const int BOARD_number = 1;
const String BOARD_hardware = "Station";
const String BOARD_name = BOARD_hardware + String(BOARD_number,DEC);
const float JSON_software_version = 0.5;
//JSON_board
//COMANDS
String COMANDS_serial;
int COMANDS_devices_int = 0;
String COMAND_device = "";
bool COMANDS_devices_bool = false;
int COMANDS_number = 0;
String COMAND_no_device;
//COMANDS
//OTHER
ESP8266WebServer server;
String Gun1 = "Gun1";
const int DEVICES_int = 1;
String DEVICES[DEVICES_int] = {Gun1};
//OTHER
  Serial.println("Booting");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  WIFI_check();
  OTA_setup();
  COMANDS();
  SERVER_web();
  WIFI_check();
  OTA();
  server.handleClient();
  COMANDS();
String JSON_board() {
  DynamicJsonBuffer jsonBuffer;
  JsonObject& root_board = jsonBuffer.createObject();
  root_board["Software Version"] = JSON_software_version;
  root_board["Name"] = BOARD_name;
  root_board["Hardware"] = BOARD_hardware;
  root_board["Number"] = BOARD_number;
  String JSON_board_json;
  root_board.prettyPrintTo(JSON_board_json);
  return JSON_board_json;
void COMANDS(){
  COMANDS_serial = Serial.readString();
  int COMAND_contains = COMANDS_serial.indexOf(DEVICES[COMANDS_devices_int]);
  if (COMAND_contains >= 0){
    for (COMANDS_devices_int = 0; COMANDS_devices_bool == true; COMANDS_devices_int++){
      if (COMAND_contains >= -1){
        COMAND_device = DEVICES[COMANDS_devices_int];
        COMAND_no_device.replace(COMAND_device, "");
        COMAND_no_device.replace(" ", "");
    COMANDS_number++;
String JSON_comands(){
  JsonObject& root_comands = jsonBuffer.createObject();
  root_comands["Gun1"]["comand_number"] = "null";
  root_comands["Gun1"]["comand"] = "null";
  root_comands[COMAND_device]["comand_number"] = COMANDS_number;
  root_comands[COMAND_device]["comand"] = COMAND_no_device;
  String JSON_comands_json;
  root_comands.prettyPrintTo(JSON_comands_json);
  return JSON_comands_json;
void SERVER_web() {
  server.on("/restart", []() {
    server.send(200, "text/plain", "Restarting ESP");
    ESP.restart();
  server.on("/update", []() {
    server.send(200, "text/plain", "Update Called \n5 seconds left");
    OTA_update = true;
    OTA_time = 0;
  server.on("/board", []() {
    server.send(200, "text/json", JSON_board());
  server.on("/comands", []() {
    server.send(200, "text/json", JSON_comands());
  server.begin();
  Serial.print("IP address: ");
void OTA_setup() {
  ArduinoOTA.setPort(OTA_port);
  ArduinoOTA.setHostname(BOARD_name.c_str());
  ArduinoOTA.setPassword(OTA_password);
  ArduinoOTA.onStart([]() {
    String OTA_type;
    if (ArduinoOTA.getCommand() == U_FLASH) {
      OTA_type = "sketch";
    } else { // U_SPIFFS
      OTA_type = "filesystem";
    Serial.println("OTA Start updating " + OTA_type);
  ArduinoOTA.onEnd([]() {
    Serial.println("\nOTA End");
  ArduinoOTA.onProgress([](unsigned int OTA_progress, unsigned int OTA_total) {
    Serial.printf("OTA Update Progress: %u%%\r", (OTA_progress / (OTA_total / 100)));
  ArduinoOTA.onError([](ota_error_t OTA_error) {
    Serial.printf("OTA Error[%u]: ", OTA_error);
    if (OTA_error == OTA_AUTH_ERROR) {
      Serial.println("OTA Auth Failed");
    } else if (OTA_error == OTA_BEGIN_ERROR) {
      Serial.println("OTA Begin Failed");
    } else if (OTA_error == OTA_CONNECT_ERROR) {
      Serial.println("OTA Connect Failed");
    } else if (OTA_error == OTA_RECEIVE_ERROR) {
      Serial.println("OTA Receive Failed");
    } else if (OTA_error == OTA_END_ERROR) {
      Serial.println("OTA End Failed");
  uint16_t OTA_time_start = millis();
    while (OTA_time < 1000)
      ArduinoOTA.handle();
      OTA_time = millis() - OTA_time_start;
      delay(10);
void WIFI_check() {
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Connection Failed! Connecting...");
    delay(100);
void OTA() {
  if (OTA_update == true) {
    while (OTA_time < 5000)
      delay(10);
    ESP.restart();
the json on the /comands should be:
"Gun1": {
"comand_number": 1,
"comand": "" },
"Gun2": {
"comand_number": 1,
"comand": "" }
it doesent work
What does that mean, please?
So when i try to write "Gun1 test" in the serial it doesent show to json on the webpage
Why do you (incorrectly) think that there is any relationship between writing some string literal to the serial monitor and sending some JSON to a server?
