Hi guys! I'm using a for loop to read a main file (saved in SPIFFS of my wemos D1 mini) and split it in 10 different smaller files, then I want to send each file over the internet through an HTTP request. Everything works great except that when I send the file through HTTP in Node-red I can see that the last object of each files is missing 2 values: AcZ and time (see the image below):
I think it's a problem of memory declaration of the JsonDocument. I'm really knew here with C++ and ArduinoJson. Anyway I read in the documentation that doc.clear() resets the memory pool but doesn’t destroy it. And I think the problem is that I'm somehow duplicating something and exceding in memory. Is this really the problem? Thanks in advance
That's how I declared the capacity of the JsonDocument:
const size_t capacity = JSON_OBJECT_SIZE(1) + JSON_OBJECT_SIZE(4) + JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(10) + 10*JSON_OBJECT_SIZE(4) + 10;
And this is the function I use to publish the values:
//------ HTTP Publish ------
void httpPublish(){
const char * outputFileNames[] = {"/out1.txt", "/out2.txt", "/out3.txt", "/out4.txt", "/out5.txt", "/out6.txt", "/out7.txt", "/out8.txt", "/out9.txt", "/out10.txt"};
const byte outputCount = sizeof outputFileNames / sizeof outputFileNames[0];
byte outputIndex = 0;
File sourceFile;
File destinationFile;
//Serial.println(capacity);
for (byte idx = 0; idx < outputCount; idx++) {
DynamicJsonDocument doc(capacity);
DynamicJsonDocument globalDoc(capacity);
StaticJsonDocument <1024> localDoc;
String aLine;
aLine.reserve(capacity);
destinationFile = LittleFS.open(outputFileNames[idx], "r");
if (!destinationFile) {
Serial.print(F("can't open destination "));
Serial.println(outputFileNames[idx]);
Serial.print("Reading: ");
//int lineCount = 0;
while (destinationFile.available()) {
aLine = destinationFile.readStringUntil('\n');
DeserializationError error = deserializeJson(localDoc, aLine);
if (!error) globalDoc.add(localDoc);
else{ Serial.println("Error Writing All files");}
}//while
JsonObject Info = doc.createNestedObject("Info");
Info["Battery"] = battery;
Info["ID"] = id;
Info["Latitudine"] = latitudine;
Info["Longitudine"] = longitudine;
JsonArray Data = doc.createNestedArray("Data");
Data.add(globalDoc);
HTTPClient http;
//Send request
http.begin("http://raspi-hyperink:1880/postjdoc");
char buffer[capacity];
size_t n = serializeJson(doc, buffer);
http.POST(buffer);
Serial.println(buffer);
http.end();
destinationFile.close();
}// end for
}//end httpPublish
