rwb
1
Code:
StaticJsonDocument < 64 > jDoc;
if (wifi_client.available()) {
deserializeJson(jDoc, wifi_client);
Serial.println("RECEIVED");
serializeJson(jDoc, Serial);
temp = jDoc["temp"];
int applied = jDoc["applied"];
Serial.print(t_current);
Serial.print(" -> ");
Serial.println(temp);
Serial.print("applied: ");
Serial.println(applied);
Output
RECEIVED
{"temp":60,"applied":41498}0 -> 60
applied: 0
Why does jDoc["applied"]
return zero instead of the value in the received JSON?
blh64
2
Make applied
of type long
41498 is larger than a signed int. You could also make it an unsigned int since they can go up to 65535.
rwb
3
Aha int
is only two bytes here butmillis()
is unsigned long
-- which is only four bytes.
That's got it; thank you
rwb
4
Spoke too soon; it now works sometimes.
RECEIVED
{"temp":60,"applied":327970}0 -> 60
applied: 0
and
JsonDocument jDocFlow;
jDocFlow["t_flow"] = t_flow;
jDocFlow["t_return"] = t_return;
Serial.println("--published temp--");
serializeJson(jDocFlow, Serial);
prints
--published temp
Noticed that I seem to be using version 7 not 6 of JSON therefore I've replaced StaticJsonDocument
with JsonDocument
rwb
5
OK, going back from JsonDocument
to StaticJsonDocument<64>
has made the value of applied
come back.
system
Closed
6
