JTAG disable problem
Hallo people, sry for my bad english :confused:
I have a problem to program a ATmega32 over the Arduino-IDE.
[u]Which works:[/u] I use a Arduino Uno as ISP to program a ATmega32 (ext. 8Mhz). I can load a program on the ATmega32 that a LED blink on D31. That's works fine:
void setup(){
   pinMode(31, OUTPUT);
  digitalWrite(31, HIGH);
  delay(100);
  digitalWrite(31, LOW);
  delay(100);
[u]My problem:[/u] Now i will use the output register C. This are the data pins D16-D23. What i become: - D16 - work fine - D17 - work fine - D18 (TCK) - LED shines continues with half power - D19 (TMS) - LED shines continues with half power - D20 (TDO) - LED shines no time - D21 (TDI) - LED shines continues with half power - D22 - work fine - D23 - work fine I think that it is a problem with the JTAG, because all 4 pins are for this. I have look in the datasheet and I have see that the 7. bit of the "Fuse High Byte" are for this. But I think this is correct in my boards.txt:
mega32-8.name=ATmega32-8mhz
mega32-8.build.mcu=atmega32
mega32-8.build.f_cpu=8000000L
mega32-8.build.core=arduino:arduino
mega32-8.build.variant=mega32
mega32-8.upload.maximum_size=32000
mega32-8.bootloader.low_fuses=0xE4
mega32-8.bootloader.high_fuses=0xD9
#mega32-8.bootloader.extended_fuses=0xFD
Have someone I idea where can come my problem? Thank you.
Sorry I can't understand the rest of your problem. Post the code that does not work not the code that works.
I program a separate ATmega32 over the Arduino IDE.
The program:
   pinMode(15, OUTPUT);
   pinMode(20, OUTPUT);
  digitalWrite(15, HIGH);
  digitalWrite(20, HIGH);
  delay(100);
  digitalWrite(15, LOW);
  digitalWrite(20, LOW);
  delay(100);
The LED at output 15 blink. The LED at output 20 not.
I can change the LED’s and the same. I have change the IC and the same. So it is no hardware problem. The ATMega32 will give no signal out at output 20.
Is there a pin mapping for pin 20 for this processor in the Arduino IDE? A quick look and I couldn't see one. Have you tried direct port mapping?
I hope you mean this: I use this file (attachment).
I have now try direct port mapping:
DDRC = DDRC | B00010000;
PORTC = PORTC | B00010000;
PORTC = PORTC & B00010000;
It’s doesn’t work.
I have see: Even I load a new program on the ATmega32, a signal come out of D18 D19 D21. I think it is something from the JTAG, because all pins which doesn’t work correct, is from it.
mega32_pins_arduino.h (4.39 KB)
I have found the solution. It was the JTAG.
to disable it, i must write this line -two- times into the setup. A have try only one time …
MCUCSR|= (1<<JTD);
MCUCSR|= (1<<JTD);
