hi all,
quick questions, running a sensor on analog0, and a coin cell on analog1, and then on analog2. both sharing the same ground, when run by themselves i get correct values. when i run them in the same sketch i get jumpy and incorrect values? any ideas? serial monitor pics enclosed.
Try two readings each time you do an analogRead, and chuck the first one away.
Right... There is really only one analog-to-digital converter in the chip, and the analog inputs are multiplexed (switched). I haven't studied the timing-diagrams, but it takes some time to process & "settle".
