I have an Arduino Deumilanove and an ENC28J60 Ethernet Shield. I need to develop an embedded web server using this.
In the code sample shown below in the "print_webpage" function, I have declared a variable as "char" (char val='5').This value is sent to the webpage using " plen=es.ES_fill_tcp_data(buf,plen,&val);"
In the webpage "5" is getting displayed. But along with that junk values are also appearing as shown --
"5UBAk"
How Can I get rid of these junk values? :~
Is the code correct?
#include "EtherShield.h"
static uint8_t mymac[6] = {
0x54,0x55,0x58,0x10,0x00,0x25};
static uint8_t myip[4] = {
192,168,0,150};
#define MYWWWPORT 80
#define BUFFER_SIZE 1000
static uint8_t buf[BUFFER_SIZE+1];
EtherShield es=EtherShield();
uint16_t http200ok(void)
return(es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n")));
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf)
uint16_t plen;
char val='5';
plen=http200ok();
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<html><head><title>Embedded Web server</title></head><body>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><h1>Embedded Web server</h1>"));
</font></h2>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("Current Value: "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</body></html>"));
return(plen);
void setup(){
// initialize enc28j60
es.ES_enc28j60Init(mymac);
// init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac,myip, MYWWWPORT);
void loop(){
uint16_t plen, dat_p;
// read packet, handle ping and wait for a tcp packet:
dat_p=es.ES_packetloop_icmp_tcp(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
/* dat_p will be unequal to zero if there is a valid
* http get */
if(dat_p==0){
// no http request
continue;
// tcp port 80 begin
if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
// head, post and other methods:
dat_p=http200ok();
dat_p=es.ES_fill_tcp_data_p(buf,dat_p,PSTR("<h1>200 OK</h1>"));
goto SENDTCP;
// just one web page in the "root directory" of the web server
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
dat_p=print_webpage(buf);
goto SENDTCP;
else{
dat_p=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 401 Unauthorized\r\nContent-Type: text/html\r\n\r\n<h1>401 Unauthorized</h1>"));
goto SENDTCP;
SENDTCP:
es.ES_www_server_reply(buf,dat_p); // send web page data
// tcp port 80 end
