estou a mais de 4 HORAS tentando solucionar esse problema,eu estou querendo juntar 2 codigos onde um segue linha e outro desvia de obstaculos,eu preciso por favor saber como posso juntar os dois para um projeto da escola
primeiro codigo:
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 100 //200
#define MAX_SPEED 100 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 150;//150
int speedSet = 0;
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=35)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor3.run(RELEASE);
motor4.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor3.run(FORWARD);
motor4.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
delay(5);
void moveBackward() {
goesForward=false;
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(5);
void turnRight() {
void turnLeft() {
segundo codigo:
//defining pins and variables
#define lefts A3
#define rights A2
//defining motors
AF_DCMotor motor3(4, MOTOR12_8KHZ);
AF_DCMotor motor4(3, MOTOR12_8KHZ);
//setting the speed of motors
motor3.setSpeed(90);
motor4.setSpeed(90);
//declaring pin types
pinMode(lefts,INPUT);
pinMode(rights,INPUT);
//begin serial communication
void loop(){
//printing values of the sensors to the serial monitor
Serial.println(analogRead(lefts));
Serial.println(analogRead(rights));
//line detected by both
if(analogRead(lefts)<=400 && analogRead(rights)<=400){
//stop
motor3.run(FORWARD); //RELEASE
motor4.run(FORWARD); //RELEASE
//line detected by left sensor
else if(analogRead(lefts)<=400 && !analogRead(rights)<=400){
//turn left
motor3.run(FORWARD); //BACKWARD
motor4.run(BACKWARD); //FORWARD
//line detected by right sensor
else if(!analogRead(lefts)<=400 && analogRead(rights)<=400){
//turn right
motor3.run(BACKWARD); //FORWARD
motor4.run(FORWARD); //BACKWARD
//line detected by none
else if(!analogRead(lefts)<=400 && !analogRead(rights)<=400){
//stop
motor3.run(RELEASE);//
motor4.run(RELEASE);//
quem puder me ajudar pfv
