Just a couple of questions
I'm making a Steering wheel with two Force Feedback motors but don't know if everything about wiring is right.
also, i'd like a little help with the program if someone would likes to help me.
it is a remake of this:
and i've found it in DIY steering wheel
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Looks like you have the Power In and Motor Out terminals swapped on one of the motor controllers.
It would be better if you drew a circuit diagram, use pen(cil) and paper and label ALL components and pinouts, as well as power supplies.
The image you have posted is misleading because the motor drivers are pictured as mirror images.
Using properly drawn diagram will make helping you so much easier.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
