Literally every mosfet I have found in examples on the Net (Si2302 etc) are now listed as obsolete in Digikey.
Their recommended replacements are not suitable for 3.3v switching.
I want an N-channel that will switch 2A off my 3.3v Nano. SMD would actually be better than through-hole, but not that fussed.
Any recommendations? I'll keep poking around for now
I think the IR part should work fine. Unless you are doing PWM, you basically need to look at three specs. The first is the G/S threshold voltage, which is the voltage at which the mosfet just begins to turn on. That should be a couple volts lower than the actual gate switching voltage you will use (3.3V). The second is the current, and the third is the on-state resistance. The IR part looks fine on all three.
Another choice might be the AOSS32136C. Digikey has a quarter-million in stock, about the same price as the IR. Similar specs.
baffled2023 is suggesting a great part. I use it doing PWM with a 5V Arduino without any problems. At 2A I see no problems, I would expect it to stay fairly cool. When you put the pull down resistor to keep it off during reset etc place it from the port pin to ground, not the gate as that forms a voltage divider. There are many other parts for less money but if the column is not to high this would be a great part.
