Just can't get 2 strings to join
Hi all. Have been googling since last night and I just can't find the correct solution for this. I know it is a simple thing, but without C experience ( only VB ) I just don't understand why this seems to be so complicated.
Yes, I know the answers are out there, but I've been hunting for hours and just can't get this resolved. Please help.
The bottom line of what I am trying to do, is to pass a string to a function (void PRtxt) and have that function work with the passed string.
Final use would be to join strings for Serial.println, or for writing to an SD card, etc.
Questions:
Is it correct in the setup() to join strings using . & or + ?
Is it correct to pass the String to PRtxt, or does it first need to be converted to a char array ?
In the PRtxt function, can I join a char and a string ( String sLine = pTxt . " doesn't exist."; ) ?
void PRtxt(char pTxt[])
    Serial.println(sLine);
void setup(void)
	Serial.print("Starting Sequence...");
    String aLine = "Test " . " text line 1";
	PRtxt(aLine);
OK. Have just found sprintf. I think this may hold the solution.
Should the following work, or will I again get conflicts between the 'char' received by the 'MKfile' function and the String I want to join to it ?
#include <SD.h>
#include <stdio.h>
const int chipSelect = 4;
void MKfile(char fName[])
  char buffer [100];
  int n;
  if (SD.exists(fName)) {
    n=sprintf (buffer, "%s %s", fName, " exists");
    Serial.println(buffer);
  else {
    n=sprintf (buffer, "WARNING : %s %s", fName, " does NOT exist");
  // open a new file and immediately close it:
  File myFile;
  myFile = SD.open(fName, FILE_WRITE);
  myFile.close();
  // Check to see if the file exists:
    n=sprintf (buffer, "The file : %s %s", fName, " exists");
  else {
    n=sprintf (buffer, "WARNING : The file : %s %s", fName, " does NOT exist.");
void setup(void)
	Serial.print("Initializing SD card...");
	// make sure that the default chip select pin is set to output, even if you don't use it:
	pinMode(10, OUTPUT);
	// see if the card is present and can be initialized:
	if (!SD.begin(chipSelect)) {
		Serial.println("Card failed, or not present");
		return;        // don't do anything more:
	Serial.println("card initialized.");
	MKfile("datalog.txt");
void loop(void)
    n=sprintf (buffer, "%s " exists", fName );
  else {
    n=sprintf (buffer, "WARNING : %s does NOT exist", fName);
Would be more natural, no?
Hi AWOL
Thanks, and Yes, I agree with you.
I am just trying to use this as an example to learn how to add different data types together.
The 'fName' is a 'char' ( as passed to the function ) whereas the other variable is a String.
So from your example, either your code or my code would work ? ( with yours being cleaner )
Yes, but...
sprintf adds a tremendous amount of code to your sketch. You can use multiple Serial.print() statements to output all the data, without the overhead of the sprintf function.
DaveO:
  else {
sprintf() will work, and your code will work - but the code you're dealing with is very straightforward, and you can avoid sprintf if you wish to rearrange the message a bit:
  Serial.print(fName);
    Serial.print(" exists");
    Serial.print(" DOES NOT EXIST");
or even
  Serial.print(  SD.exists(fName)  ?  " exists"  : " DOES NOT EXIST"  );
for slightly shorter code
