I'm trying to change the button example to work with multiple buttons and LEDs.
So I decided to create a function (my first) to just "link" the input and output pins.
Am I missing something under setup?
Here's my code:
int buttonPin = 0; // variable for the input pin
int outputPin = 0; // variable for the output pin
void turnOnLED(int buttonPin, int outputPin) {
// check if the button is pressed.
// if it is, the buttonPin is HIGH:
if (buttonPin == HIGH) {
// turn LED on:
digitalWrite(outputPin, HIGH);
// turn LED off:
digitalWrite(outputPin, LOW);
// initialize the LED pin as an output:
pinMode(outputPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
turnOnLED (22, 13);
seems weird... are you sure your input pin and output pin are the same and connected to pin 0 (which is used by the Serial connection as well)
Also pins are better declared as `cont byte` rather than `int`
I want the function to chnage the pin number
in this case, buttonPin to 22 and outputPin to 13
updated code:
int buttonPin; // variable for the input pin
int outputPin; // variable for the output pin
if (digitalRead(buttonPin) == HIGH) {
// turn LED on:
// turn LED off:
turnOnLED (22, 13);
Well then what are your pinMode() instructions referring to in the setup()?
To read from a pin it must be an INPUT, to write to a pin it must be an OUTPUT
What is the value of buttonPin at this point?
on the updated code I hoped it to have no value and only assign one when the function is called
J-M-L:
I get what you are saying, there is no pin referal before setup sets pinModes.
but does that mean I have to "manually" set all the pins before setup()? then write the variables names in the function arguments instead of just the number?
Well you could "manually" set them to the correct pinMode() before reading and writting to the pins, in your function ...
But usually you know ahead of time what is an input and what is an output depending on how you wired things, so that's why this is usually done in the setup()
J-M-L:
so I can define pinModes outside setup()? if I just move the pinModes inside the function it should be fine. right?
Tell me if I understood well. When I state the function as:
everytime I write "buttonPin" or "outputPin" it will be replaced by the values I state when calling the function in this case 22 and 13:
turnOnLED (22, 13);
This would be the function?:
// turn LED on:
// turn LED off:
void turnOnLED(byte buttonPin, byte outputPin) {
// turn LED on:
// delay(500);
// turn LED off:
turnOnLED (22, 13);
Well that was not really my point - hence the note in parenthesis - I was just trying to say that these are not the best pins to use (esp when you start, using serial to debug might come handy)
( his code was hinting at an output being on pin 0)
