Just downloaded 1.0.2
Is there some standard place to keep our libraries & board variants vs copying them into the new environment every time?
Libraries should be put in {Sketchbook Directory}/libraries/ to survive upgrades.
Board variants should be put in {Sketchbook Directory}/hardware/ to survive upgrades.
Thanks, will givet that a try. Turns out the libraries folder was already there, with some stuff I don't recognize in it. Made a new hardware folder, and will copy my 1284 stuff into it.
CrossRoads: Turns out the libraries folder was already there, with some stuff I don't recognize in it.
Been there!
opinion about the 1.0.2? plus? minus? equal?
Seemed to get past initial splash screen faster compared to 1.0 & 1.0.1. That's all I've done so far. I only noticed it because I saw the release notes posted in the International forum.
Still no '1284P boards tho ...
ARDUINO 1.0.2 - 2012.11.05
[hardware]
* Added support for the Arduino Micro.
* Added support for the LilyPad Arduino USB.
* For Arduino Mega, having avrdude use "wiring" not "stk500v2" for
  uploads (to improve auto-reset behavior).
  http://code.google.com/p/arduino/issues/detail?id=806
[environment]
* Find-In-Reference now works whether or not text is selected.
  http://code.google.com/p/arduino/issues/detail?id=940
* Not generating prototypes for functions that already have them.
  (Lars J. Nielsen).
  http://code.google.com/p/arduino/issues/detail?id=973
* Improved line numbers for error messages. (Paul Stoffregen)
  http://code.google.com/p/arduino/issues/detail?id=907
* Automatically create libraries folder in the sketchbook.
  (Paul Stoffregen)
  http://code.google.com/p/arduino/issues/detail?id=986
* Tutorial on installing libraries (linked from readme.txt in the
  libraries folder). (Limor Fried)
* Fix to allow selection of Norwegian. (Rune Fauske)
* Fix to race condition / occasional error in compilation. (gandrewstone)
  http://code.google.com/p/arduino/issues/detail?id=950
* Don't break long C++ comments during auto-format.
  http://code.google.com/p/arduino/issues/detail?id=255
[core / libraries]
* Included WiFi library and wifi shield firmware.
* Added ability to specify serial configuration (data bits, stop bits
  and parity check) in Serial.begin(). (Alarus)
  http://code.google.com/p/arduino/issues/detail?id=770
* Avoided overruns of the incoming serial (CDC) buffer on the Leonardo.
  (Peter Van Hoyweghen)
* Avoided auto-reset of the Leonardo when opening serial port after
  upload without specifying a baud rate. (Peter Van Hoyweghen)
* Fix for tone() on the Leonardo. (Shigeru Kanemoto)
  http://code.google.com/p/arduino/issues/detail?id=960
* Fix for SD library on Leonardo.
  http://code.google.com/p/arduino/issues/detail?id=931
* Added other write functions on Leonardo.
  http://code.google.com/p/arduino/issues/detail?id=958
* Added support for Leonardo interrupts 2 and 3. (Kristian Lauszus)
* Print ovf, inf, or nan accordingly in Serial.print(). (Nick Gammon)
  http://code.google.com/p/arduino/issues/detail?id=946
  http://code.google.com/p/arduino/issues/detail?id=961
  http://code.google.com/p/arduino/issues/detail?id=967
* Fix initialization of SPI data lines. (gandrewstone)
  http://code.google.com/p/arduino/issues/detail?id=888
* Serial.flush() waits for last byte to transmit. (michele.mazzucchi)
  http://code.google.com/p/arduino/issues/detail?id=871
* Adding overloads so Serial.write(0) works.
  http://code.google.com/p/arduino/issues/detail?id=1006
[build]
* Fix Linux arduino script when there are spaces in directory name.
* Pass Linux command line arguments from arduino script through to the
  Java code. (Allows specifying sketch to open on command line.)
[examples]
* Included examples for the starter kit.
This program crashes after 3 iterations, :
  int n = 0;
  while(n <= 100) {
    int u = 20*n;
    int v = 30*n;
    String str = String(n) + ", " + String(u) + ", " + String(v);
    Serial.println(str);
    n++;
  Serial.println("Done");
They haven't fixed the free() bug!
http://code.google.com/p/arduino/issues/detail?id=857 http://code.google.com/p/arduino/issues/detail?id=411
How many more releases?
(edit)
Also, new.cpp still doesn't have placement new in it, nor new[] or delete[].
