Just For The Heck Of It (Maybe A Future Project)
Well, (In my dreams...) I want to build a huge tv center... I want to have a main 42" or 47" tv and two smaller ones (32 or so?); one on either side...
When the tv is off, they could be tilted at 45 degree angles, and when one is on, it is at the normal horizontal position...
For this, I know I need 2 big servos and a way to detect if the tv is on or off...
I could use an ir detect it, but I have another idea... I am most likely going to have an IR Repeater, so I could just use one of the emitters from it and read it directly...
My questions are:
Would an IR Detector or the repeater be easier?
AND
What servo would be good for this situation? If a servi is impractical, what should I use instead?
None you could afford, even at surplus prices.
Since you don't need to move the screens very fast, very often, or with extreme precision, a simple piece of threaded rod from Home Despot, driven by a stepper motor, with a nut that moves arms to push out/pull in the swinging ends of your "surround screens" should be beter than "good enough".
Curious - what is the point of tilting the TVs? Horizontally or vertically?
I would personally tap directly into the power supply of the TV, and see if I could find a 3.3 VDC or 5VDC output that is only on when the TV is on (or maybe find a digital signal somewhere on the TV for the same). It would void any warranty on the TVs, though. You might also try to detect the backlight of the TV in some manner.
Lastly - presuming you get to the point of actually doing this, why do you need that much TV? I have a 42" LCD sitting on my wall that rarely gets turned on (the occasional DVD movie is about it); one of the best things I and my wife ever did was to drop cable TV. There's very little on it that is worthwhile, and anything you generally do want to watch can be found online in some format, or thru other "channels".
Now - if you are intending this to be for some form of "ultimate computer display system" (aka - like a mega/giga-pixel display wall, or some kind of multi-head simulator surround system) - that may be used for watching the occasional bit of entertainment; sign me up! I love my dual-head system I have on my desk (dual 22" 1680x1050 LCDs right now); a system like you're proposing would be heaven, if I had the desk room (which I don't, unfortunately)...
:slight_smile:
Well, tilting them would look cool... And I mean that the top right of the left one and the top left of the right one would be tilted up....
Why not?
I have two TVs in my lounge, one 37" HD tv and one 23" CRT. I game and watch TV at the same time.
You might be able to use one of those motors for pointing satellite dishes in different directions.
Sensing that the TV is on, you could experiment with a little wire antenna on a floating analog input.
I would expect the TV to emit a lot more electrical noise when it's on than when its off.
Like the power LED for example?
Yeah... Pulling apart a $500 tv that doesn't even really belong to me (Christmas / Birthday Presents) is a bad idea...
Only if you can't reassemble it undetectably :slight_smile:
Put some sort of current detector on the A.C. power.
You could probably use a hall effect sensor next to the power cable of a telly to detect when it's on, since the telly's power consumption will change considerably the electromagnetic field around the cable will change.
