Just getting started with XBee
I have the XBees and the antennae. Just running into a little problem.
The U.FL connectors refuse to mate. How much force do you need for the first time you connect it? I'm afraid of breaking the XBee's thin, fragile PCB.
Also, on all of the antennae (including two unopened ones) - the U.FL connector isn't quite circular. It's more egg-shaped. It looks as if it would fit, but... is this typical?
I have dealt with U.FL before (in a netbook) and it was easy and simple, nothing like this.
Very little.
As well you should be.
No. They should be round.
As it should be.
Thanks a ton, PaulS! Guess these are probably defective, then...
