I tried the new build but no luck. So I uninstalled and tried to install 1.6.7, but it didn't install correctly. 1.6.6 did, so I'm using that.
How long does it take to upload, though? I'm not getting errors, but it's been like 10 minutes.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
Code:
/* Creation Crate Mood Lamp
This lamp smoothly cycles through a colour spectrum.
It only turns on when its surroundings are dark.
Colour equations (we’ll be using these later):
Red = sin(x)
Green = sin(x + PI/3)
Blue = sin(x + 2PI/3)
These equations are how the program will calculate the brightness of
the LEDs.
Step 1: Input User Defined Variables
Think of variables like containers - they’re used to store information. */
int pulseSpeed = 5;
// This value controls how fast the mood lamp runs. You can replace this with any whole number.
int ldrPin = 0; // LDR in Analog Input 0 to read the surrounding light.
int redLed = 11; // red LED in Digital Pin 11.
int greenLed = 10; // green LED in Digital Pin 10.
int blueLed = 9; // blue LED in DIgital Pin 9.
// These are the pins we are using with the UNO R3 (Arduino-compatible). You can see the numbers on the board itself.
int ambientLight;
// This variable stores the value of the light in the room.
int power = 150;
// This variable controls the brightness of the lamp (2-255).
float RGB[3];
// This is an ‘array’. It can hold 3 values: RGB[0], RGB[1], and RGB[2].We’ll use this to store the values of the Red, Blue, and Green LEDs.
float CommonMathVariable = 180/PI;
/* We will be using the value of 180/PI a lot in the main loop, so to
save time, we will calculate it once here in the setup and store it
in CommonMathVariable. Note: it is PI, not P1 */
/* Step 2: Create Setup Loop
This ‘loop’ is not really a loop. It runs once in the beginning to create
the default values for our LEDs. */
void setup () {
pinMode (redLed,OUTPUT);
pinMode (greenLed,OUTPUT);
pinMode (blueLed,OUTPUT);
// This tells the UNO R3 to send data out to the LEDs.
digitalWrite (redLed,LOW);
digitalWrite (greenLed,LOW);
digitalWrite (blueLed,LOW);
// This sets all the outputs (LEDs) to low (as in off), so that they do not turn on during startup.
} // Opening brackets must be accompanied by closing brackets.
/* Step 3: Create Main Loop
The previous sections are where we set up the variables. This section is
where we put them to work! This part of the program is a ‘loop’. It
repeats itself over and over again, making a small change in the
brightness of the LEDs each time - this creates a smooth transition in
colour. */
void loop () {
for (float x = 0; x < PI; x = x + 0.00001) {
RGB[0] = power * abs(sin(x * (CommonMathVariable))); // Red LED.
RGB[1] = power * abs(sin((x + PI/3) * (CommonMathVariable))); // Green LED.
RGB[2] = power * abs(sin((x + (2 * PI) / 3) * (CommonMathVariable))); // Blue LED.
ambientLight = analogRead(ldrPin);
// This reads the light in the room and stores it as a number.
if (ambientLight > 600) {
// This ‘if statement’ will make the lamp turn on only if it is dark. The darker it is, the higher the number.
analogWrite (redLed,RGB[0]);
analogWrite (greenLed,RGB[1]);
analogWrite (blueLed,RGB[2]);
// These ‘analogWrite’ statements will send the values calculated above to the LEDs.
} // Don’t forget to close this ‘if statement’ with a bracket!
else {
// This ‘else statement’ will only activate if the ‘if statement’ above does not (ie. If it is too bright in the room). The LEDs will turn off.
for (int i = 0; i < 3; i++) {
// This loop calculates the delay for each colour depending on its current brightness. Brighter LEDs will change colour slower and vice versa.
if (RGB < 1) {
delay (20 * pulseSpeed);
else if (RGB < 5) {
delay (10 * pulseSpeed);
else if (RGB < 10) {
delay (2 * pulseSpeed);
else if (RGB < 100) {
delay (1 * pulseSpeed);
*// ’else if’ means only one of these conditions can activate at a time. *
else {}
// This blank ‘else statement’ is a fail-safe mechanism. It instructs the program to do nothing if the conditions above do not activate. This prevents the program from generating errors when calculating delays.
delay(1);
// This delay gives the light dependent resistor time to settle and give accurate readings.
} // Don’t forget to close with these brackets!
