I keep getting a message that says I didn't define the variable "second", "hour" and "minute" but I did already defined it earlier. Any help would be appreciated. Thank you!
#include <Wire.h>
#include <Keypad.h>
//#include <iostream>
//#include <string>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define BUZZER_PIN 10
#define BUTTON_PIN 11
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 3; //three columns
char keys[ROW_NUM][COLUMN_NUM] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'0','0','0'}
byte pin_rows[ROW_NUM] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {5, 4, 3}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
void setup(){
lcd.init(); // initialize the lcd
lcd.init();
lcd.backlight();
pinMode(BUZZER_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
lcd.setCursor(2,0);
lcd.setCursor(2,0);
lcd.print(" : : ");
lcd.setCursor(4,1);
lcd.print("Set timer");
boolean typable = true;
int currentNum = 2;
int currentRow = 0;
int passnum1 = 0;
int lastState = HIGH;
int currentState;
void(* resetFunc) (void) = 0;
boolean exploded = false;
boolean settingtime = true;
boolean firstSetup = false;
void loop(){
int currentState = digitalRead(BUTTON_PIN);
Serial.println(currentState);
//delay(100);
//if(typable){
char key = keypad.getKey();
if (settingtime && currentNum == 4){
currentNum = 7;
if (settingtime && currentNum == 9){
currentNum = 12;
if (settingtime && currentNum == 14){
settingtime = false;
passnum1 = 0;
currentNum = 4;
currentRow = 1;
lcd.setCursor(2,0);
lcd.print("Set password");
lcd.setCursor(0,1);
lcd.print(" ");
if (key && typable){
if (exploded){
resetFunc();
if (!(key == "*") && !(key == "#")){
lcd.setCursor(currentNum,currentRow);
lcd.print(key);
currentNum++;
beep(4000, random(40,10));
passnum1++;
int second = 30;
int minute = 0;
int hour = 0;
char firsthournum;
char firstminutenum;
char firstsecondnum;
char secondhournum;
char secondminutenum;
char secondsecondnum;
//timer value gatherer
if (settingtime && currentNum == 2){
firsthournum = (key);
if (settingtime && currentNum == 3){
secondhournum = (key);
hour = (int(firsthournum + secondhournum));
if (settingtime && currentNum == 7){
firstminutenum = (key);
if (settingtime && currentNum == 8){
secondminutenum = (key);
minute = (int(firstminutenum + secondminutenum));
if (settingtime && currentNum == 12){
firstsecondnum = (key);
if (settingtime && currentNum == 13){
secondsecondnum = (key);
second = (int(firstsecondnum + secondsecondnum));
if(settingtime == false){
if(firstSetup == false){
if(passnum1 == 8){
passnum1 = 9;
typable = false;
lcd.setCursor(2,0);
lcd.print("Password Set");
beep(100, random(250)); beep(100, random(250)); beep(100, random(250)); beep(100, random(250)); beep(100, random(250)); beep(100, random(250)); beep(100, random(250));
lcd.setCursor(4,1);
lcd.print("********");
delay(2000);
// count down
lcd.setCursor(2,0);
lcd.print(" : : ");
//set time
int delayamount = 1000;
//timer loop
boolean countdown = true;
while(countdown){
delay(10);
second--;
analogWrite(BUZZER_PIN, 200);
delay(delayamount / 4);
analogWrite(BUZZER_PIN, 0);
delay((delayamount / 4) * 3);
if (second == 0){
if (!(minute == 0)){
minute--;
second = 59;
if (minute == 0){
if (!(hour == 0)){
hour--;
minute = 59;
lcd.setCursor(2,0);
lcd.print(String(hour));
lcd.setCursor(7,0);
lcd.print(String(minute));
lcd.setCursor(12,0);
lcd.print(String(second));
lcdcheck(second, 13);
lcdcheck(minute, 8);
lcdcheck(hour, 3);
if((hour == 0) && (minute == 0) && (second == 0)){
countdown = false;
if (countdown == false){
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(2,0);
lcd.print("The bomb has");
lcd.setCursor(4,1);
lcd.print("exploded");
analogWrite(BUZZER_PIN, 250);
delay(5000);
exploded = true;
typable = true;
void beep(unsigned char delayms, int intensity){
analogWrite(BUZZER_PIN, intensity);
delay(delayms);
delay(delayms);
void lcdcheck(int num, int pos){
if (num < 10){
lcd.setCursor(pos, 0);
lcd.print(" ");
