Hi everyone,
I’m trying to read my Piaggio Zip 4T Euro 5 ECU using an ESP32-C3 + MC33660 (K-line transceiver), but I’m only getting my own command echoes and no real ECU response. Hoping for some expert advice!
My Setup:
- MC33660 connected to ESP32-C3 (RX: GPIO20, TX: GPIO21, CEN: 3.3V).
- K-line wired to K Line + 1kΩ pull-up to 12V.
- Scooter ignition ON.
What I’ve Tried:
- Baud rates tested: 10400, 9600, 4800.
- ECU addresses tried:
0xF1,0x33,0x7E. - Wakeup sequences:
- Standard KWP2000 (
0x81 0x13 [ADDR] 0x81). - Alternative (
0xC0 0x33 [ADDR] 0x81).
- Disabled echo (
0x85). - Hardware checks:
- K-line shows ~12V at idle (with pull-up).
- No TX/RX shorts.
Result:
Only my own commands echoed back, e.g.:
Sent: 68 6A F1 01 01 0C FF
Received: 68 6A F1 01 01 0C FF (no real ECU data)
No error codes, no RPM, no actual response.
Questions:
- Does the Piaggio Zip Euro 5 even support K-line diagnostics?
- Is
0xF1the correct ECU address, or is there a different protocol? - Am I missing a step in initialization?
- Has anyone successfully reverse-engineered Piaggio’s Euro 5 ECUs?
I've hit a wall after days of testing. Any insights would be hugely appreciated! I tried using ChatGPT but didn’t get very far with the responses I got.
Code:
#include <HardwareSerial.h>
#define KLINE_RX_PIN 20 // GPIO20 = RX
#define KLINE_TX_PIN 21 // GPIO21 = TX
#define CEN_PIN 4 // GPIO4 - MC33660 enable
HardwareSerial KLine(1); // UART1
// K-line parameters
const uint32_t baudrates[] = {10400, 9600, 4800};
const uint8_t ecuAddresses[] = {0xF1, 0x33, 0x7E};
pinMode(CEN_PIN, OUTPUT);
digitalWrite(CEN_PIN, HIGH);
testKLineConnection();
void testKLineConnection() {
for (auto baud : baudrates) {
KLine.begin(baud, SERIAL_8N1, KLINE_RX_PIN, KLINE_TX_PIN);
Serial.print("\nTesting baudrate: ");
Serial.println(baud);
for (auto addr : ecuAddresses) {
Serial.print("\nAttempting ECU address 0x");
Serial.println(addr, HEX);
digitalWrite(CEN_PIN, LOW);
delay(100);
delay(200);
uint8_t wakeup[] = {0x81, 0x13, addr, 0x81};
KLine.write(wakeup, sizeof(wakeup));
delay(300);
KLine.write(0x85);
delay(50);
uint8_t request[] = {0x68, 0x6A, addr, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0xD9};
KLine.write(request, sizeof(request));
KLine.flush();
if (KLine.available()) {
Serial.print("ECU response: ");
while (KLine.available()) {
Serial.print(KLine.read(), HEX);
Serial.print(" ");
Serial.println("Communication found!");
return;
Serial.println("No Communication!");
Thanks in advance!
