k type thermocouple(help needed)
Hello,
I have made a k type 8 probe thermocouple by using,
1)arduino mega 2560
2)thermocouple wire with module(max6675)
https://www.amazon.com/HiLetgo-MAX6675-Thermocouple-Temperature-Arduino/dp/B01HT871SO/ref=pd_sim_328_2?_encoding=UTF8&pd_rd_i=B01HT871SO&pd_rd_r=GF1YKPQ0FMNDF27YQ6N1&pd_rd_w=urBAO&pd_rd_wg=pWcg5&psc=1&refRID=GF1YKPQ0FMNDF27YQ6N1
By using 8 probe i measure 8 different temperature of an object(T1 to T8)
and average the total temperature.
This is my code.
//group 69
//8 tem only total and average with lcd
#include "max6675.h"
#include<Wire.h>
#include<LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,20,4);
int ktcS01 = 2;
int ktcCS1 = 3;
int ktcCLK1 = 4;
MAX6675 ktcl(ktcCLK1, ktcCS1, ktcS01);
int ktcS02 = 5;
int ktcCS2 = 6;
int ktcCLK2 = 7;
MAX6675 ktc2(ktcCLK2, ktcCS2, ktcS02);
int ktcS03 = 8;
int ktcCS3 = 9;
int ktcCLK3 = 10;
MAX6675 ktc3(ktcCLK3, ktcCS3, ktcS03);
int ktcS04 = 11;
int ktcCS4 = 12;
int ktcCLK4 = 13;
MAX6675 ktc4(ktcCLK4, ktcCS4, ktcS04);
int ktcS05 = 22;
int ktcCS5 = 23;
int ktcCLK5 = 24;
MAX6675 ktc5(ktcCLK5, ktcCS5, ktcS05);
int ktcS06 = 25;
int ktcCS6 = 26;
int ktcCLK6 = 27;
MAX6675 ktc6(ktcCLK6, ktcCS6, ktcS06);
int ktcS07 = 28;
int ktcCS7 = 29;
int ktcCLK7 = 30;
MAX6675 ktc7(ktcCLK7, ktcCS7, ktcS07);
int ktcS08 = 31;
int ktcCS8 = 32;
int ktcCLK8 = 33;
MAX6675 ktc8(ktcCLK8, ktcCS8, ktcS08);
int Tot = 0;
int Ave = 0;
void setup(){
lcd.begin();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Group# 69");
lcd.setCursor(0,1);
lcd.print("Final Output");
lcd.setCursor(0,2);
lcd.print("Tot=        Deg Cel");
lcd.setCursor(0,3);
lcd.print("Ave=        Deg Cel");
//put the main code here, to run repeatedly:
//basic readout test
Serial.print("T1 = ");
Serial.print(ktcl.readCelsius());
Serial.print("  ");
Serial.print("T2 = ");
Serial.print(ktc2.readCelsius());
Serial.print("  ");
Serial.print("T3 = ");
Serial.print(ktc3.readCelsius());
Serial.print("  ");
Serial.print("T4 = ");
Serial.print(ktc4.readCelsius());
Serial.print("  ");
Serial.print("T5 = ");
Serial.print(ktc5.readCelsius());
Serial.print("  ");
Serial.print("T6 = ");
Serial.print(ktc6.readCelsius());
Serial.print("  ");
Serial.print("T7 = ");
Serial.print(ktc7.readCelsius());
Serial.print("  ");
Serial.print("T8 = ");
Serial.print(ktc8.readCelsius());
Serial.println("  ");
Serial.print("Group# 69");
Serial.print("  ");
lcd.setCursor(5,0);
Serial.print("Final Output");
Serial.print("  ");
lcd.setCursor(5,1);
Serial.print("Tot = ");
Serial.print(ktcl.readCelsius()+ktc2.readCelsius()+ktc3.readCelsius()+ktc4.readCelsius()+ktc5.readCelsius()+ktc6.readCelsius()+ktc7.readCelsius()+ktc8.readCelsius());
Serial.print("  ");
lcd.setCursor(5,2);
lcd.print(ktcl.readCelsius()+ktc2.readCelsius()+ktc3.readCelsius()+ktc4.readCelsius()+ktc5.readCelsius()+ktc6.readCelsius()+ktc7.readCelsius()+ktc8.readCelsius());
Serial.print("Ave = ");
Serial.print((ktcl.readCelsius()+ktc2.readCelsius()+ktc3.readCelsius()+ktc4.readCelsius()+ktc5.readCelsius()+ktc6.readCelsius()+ktc7.readCelsius()+ktc8.readCelsius())/8);
Serial.print("  ");
lcd.setCursor(5,3);
lcd.print((ktcl.readCelsius()+ktc2.readCelsius()+ktc3.readCelsius()+ktc4.readCelsius()+ktc5.readCelsius()+ktc6.readCelsius()+ktc7.readCelsius()+ktc8.readCelsius())/8);
But now I want to use Arduino Thermocouple Multiplexer Shield (K - MAX31855K) instead of max 6675.
Can you please help me with the code and if possible help me with the schematic circuit diagram also.
Thank you :slight_smile:
Please edit your post to add code tags, as described in the "How to use this forum" post.
anikimran: But now I want to use Arduino Thermocouple Multiplexer Shield (K - MAX31855K) instead of max 6675.
http://www.electronics123.com/shop/product/kta-259k-tba-arduino-thermocouple-multiplexer-shield-k-max31855k-with-headers-8262
As I don't have one of these modules, all I can say is there is information that looks complete and a sketch provided.
What is wrong with the information and example sketch provided on the website link you provided?
Can you provide me the library code for k max 31855?
I want to measure 8 diff. temperature at a time by using 8 thermocouple probe and sum it and average the total temp.
The link YOU provided gives both a library and an example sketch - what more do you need?
Allan
anikimran: Can you provide me the library code for k max 31855?
Sure.
http://www.electronics123.net/amazon/software/TCMuxV3.zip
