Hello!
I recently got the RFID/keypad above but I’ve gotten to some problems. I did some searching on the forums and found some sample code (http://www.arduino.cc/cgibin/yabb2/YaBB.pl?num=1240374471/15). The problem is that I don’t get any output from the arduino when I try to scan the RFID card I use to enter my school. What might cause this is that the card is not compatible with the Wiegand reader but I will get some card that is supposed to work soon. But what makes me wonder is that I don’t get any output when I press the buttons on the keypad either?.
So now I wonder if anyone can help me to figure this out? it would be really helpful.
Okay. I tried to add some that would send a message to the serial port every time the interrupter was triggered but it never triggers when I press the buttons on the keypad(the buttons is also supposed to go over the D0/D1 lanes.
Have you got pull up resistors on the outputs they are mainly open collector. Do you know how many bits you are expecting?
Does the keypad output each key as it is pressed, wait until the # is pressed or wait until so many keys have been pressed, all three are options that are used.
That data sheet you posted is rubbish get back to your supplier and get a proper one.
