KaraClass a GUI user screen environment based on marekburiak.github.io/ILI934
karaClass
karaClass is a skeleton to build structured user screen on ILI9341 touch screen (around 6$ in china) for arduino due.
Probably it can work on other boards like mega or teensy and with other library
Defined main classes are:
TScreen: the screen itself
TPanels: a container of TPanel and TButtons
TPanel: the main part of the screen
TButtons: a container of raw of TButtons. displayed from bottom to top of TPanels
TButton: a button
TStBar: a panel at the top of the screen. It contains TStatus object.
TKeyboard: a complete qwerty keyboard
A TButtons panel can be in group mode ie only all TButton are in toggle mode but only one can be On.<
A TButton can be a simple push button or a toggle button (bi-stable) with or without an image and with a caption.
See the example to show these elements in action.
The example needs additional libraries:
RTClib
SdFat
SdFatUtil
IniFile.h
DueTimer cannot live without it
https://github.com/karawin/karaClass/blob/master/2016-03-04.10.52.02.jpg
Video:
Hello,
Version 1.02 sur github
Some new classes
onTouch and onUntouch events
etc....
Great work Jean-Pierre. If I ever get to update ILI9341_due documentation, do you mind if I post a link to your video?
For sure :slight_smile:
I will make a new one for 1.03 release soon. (a slider added, an onSlide action added and some cosmetic changes and organization in the code)
Hello,
Version 1.03 on github
Some new classes
onSlide, onTouch and onUntouch events
TSlider
Pattern for user code.
New video
how can we edit this library to use with arduino mega and the screen in link;
http://www.aliexpress.com/item/for-Arduino-3-2-inch-TFT-LCD-Touch-Screen-Module-Display-Ultra-HD-320X240-ILI9341-Compatible/32546709832.html
KaraClass is based on ILI9341_due.h - Arduino Due library for interfacing with ILI9341-based TFTs
You have to adapt to a new TFT library for your screen, change the DueTimer to an equivalent for the mega, and that's it :wink:
ILI9341_due works on Mega, Uno, Nano, Pro Mini...as well.
Great. Only DueTimer to adapt.
Not so hard.
How can I make this work on Uno?
What can replace the DueTimer?
