The IDE KB shortcut for Sketch > Show sketch folder is shown as <Ctrl+K>, but I've never been able to get it to work. Anyone else?
Works fine for me
Windows 10
IDE 1.8.13
Same (it works) here.
Windows 7
IDE 1.8.13
IDE 2.0.0 beta 12
Thanks both. Is that from anywhere? It works for me only after selecting Sketches in the menu. I can then use Ctrl+K, although obviously it would then be just as easy to click with mouse.
I’ve been searching for a conflict of some sort but can’t find one.
It works at any time that I have a sketch open, even immediately after File/New although until the sketch is save it opens at a temporary folder, for instance C:\Users\Bob2\AppData\Local\Temp\untitled755145902.tmp\sketch_nov17g
On 2.0.0 beta 12 it's Alt-Ctrl-K, but it works on both versions from the editor pane.
Clutching at straws but I wonder if it’s dependent on Windows version and build? I’ve just checked with my old XP PC in the shed workshop, and there’s no problem.
This is Win 10 Pro 20H2 (19042.1348) with IDE 1.8.13
BTW, is it not possible to add a signature here, where that could be included? Failing any obvious method I tried the Web box but predictably simple text was rejected.
