Hello,
i’m in the process of building a project to water my garden. I have:
- Arduino Uno wifi rev2
- Relay (8 ports) with valves attached
- Two temp/humid sensors
The code is uploading sensordata and weatherforecast (meteoserver) every hour at 5 minutes past the hour to a database on my homeserver. This part works (as long as my wifi isnt dropping).
Since a few days, my arduino board is losing its wifi connection with my wifinetwork after ‘a bit’. Sometimes 10 seconds, another time its after 30 seconds or a few minutes.
The connection starts with wifi status 3. When its connection is about to drop the wifistatus changes from 3 to 255. Not long after that the ipadress is 0.0.0.0.
In github there is a post that suggests to introduce a delay in the loop. I have a delay (1000) in the loop.
I can’t seem to figger out what i am doing wrong. The board is updated to 1.2.1 and the libraries i use to their latest versions. Is my board faulty or am i doing something wroing in my code (newbie here)?
Many thanks for any help!
Scoobie
My code:
#include <NTPClient.h>
#include <ArduinoHttpClient.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
#include <Wire.h>
#include <WiFiUdp.h>
#include "DFRobot_SHT20.h"
extern "C" {
#include "utility/twi.h"
#define TCAADDR 0x70
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int waterdruk =1;
String apiKeyValue = "aapjessleutel";
const char serverName[] = "homeserver.nl"; // server name
float zover =0;
int pinArray[] = {2,3,4,5,6,7}; // define the pins that will connect to the relays
//pin2 = schuur1
//pin3 = schuur2
//pin4 = schuur3
//pin5 = schuur4
//pin6 = zweet1
//pin7 = pomp1
int port = 80;
int getDay();
int getHours();
int getMinutes();
int getSeconds();
DFRobot_SHT20 sht20[2];
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverName, port);
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "nl.pool.ntp.org", 7200, 600000); // 7200 is tijdsverschil, 600k is updatefrequentie in ms
int status = WL_IDLE_STATUS;
for (int i = 0; i < (sizeof(pinArray)/sizeof(int)); i++){
pinMode(pinArray[i],OUTPUT);
digitalWrite(pinArray[i], HIGH); // initialise all relays to HIGH (= off)
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
delay(10000);
Serial.print("You're connected to the network");
Wire.begin();
timeClient.begin();
timeClient.update();
Serial.println(WiFi.status());
//sensor1: schuur
Wire.beginTransmission(TCAADDR);
Wire.write(1 << 1);
Wire.endTransmission();
sht20[1].initSHT20();
delay(100);
float humd = sht20[1].readHumidity();
float temp = sht20[1].readTemperature();
//sensor2: tuin
Wire.write(1 << 2);
sht20[2].initSHT20();
delay(100);
float humd2 = sht20[2].readHumidity();
float temp2 = sht20[2].readTemperature();
if (timeClient.getMinutes() == 5) {
Serial.println("making POST request sensordata");
String httpRequestData = "api_key=" + apiKeyValue + "&humtemp_schuur_humid=" + humd + "&humtemp_schuur_temp=" + temp + "&humtemp_tuin_humid=" + humd2 + "&humtemp_tuin_temp=" + temp2 + "&waterdruk=" + waterdruk + "";
String contentType = "application/x-www-form-urlencoded";
client.post("/post-esp-data.php", contentType, httpRequestData);
int statusCode = client.responseStatusCode();
Serial.print("Status code sensor datadump: ");
Serial.println(statusCode);
String response = client.responseBody();
Serial.print("Response sensor datadump: ");
Serial.println(response);
Serial.println("Wachttijd: 1 minuut");
delay(60000);
Serial.println("making POST request meteo");
String httpRequestData2 = "api_key=" + apiKeyValue + "";
client.post("/meteo.php", contentType, httpRequestData2);
Serial.print("Status code meteo: ");
String response2 = client.responseBody();
Serial.print("Response meteo: ");
Serial.println(response2);
delay(60000);
