Hi all.
I have set up a iot server (thingsboard) in my campervan monitoring temperature and humidity. This works.
I also have a voltage monitor running, not connected to thingsboard.
If my leisure battery drops below 12v a buzzer will sound. This works too.
Now i have combined these two together and this works too. Copied the temperature and humidity code from the linke tutorial, edited that and added it to the original code so i also have voltage readings reported on my dashboard.
Here comes the part where i got stuck. If the wifi acces point goes down, the sketch stops and wont go into loop. Thus not measuring my voltage anymore and not warning me when voltage drops to low.
Can any of you point me in the right direction, where do i need to start editing the code to have it report data when online but also monitor my voltage and respond to low voltage when wifi ap is down?
Here is the code i have now. Taken from this tutorial:
And added the voltage monitor code from one of the forum members here.
temperatuur, vochtigheid en voltage wordt verstuurd naar thingsboard
poging tot monitoren ook zonder internet verbinding
#include "DHT.h"
#include <WiFiEspClient.h>
#include <WiFiEsp.h>
#include <WiFiEspUdp.h>
#include <PubSubClient.h>
#include "SoftwareSerial.h"
#define WIFI_AP "HUIS"
#define WIFI_PASSWORD "12345678"
#define TOKEN "TEMP_VOLT_HUM"
// DHT
#define DHTPIN 4
#define DHTTYPE DHT11
char thingsboardServer[] = "192.168.4.2";
int buzzer = 11; //BUZZER OP PIN 11
unsigned int total; // holds readings
float voltage; // converted to volt
// Initialize the Ethernet client object
WiFiEspClient espClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
PubSubClient client(espClient);
SoftwareSerial soft(2, 3); // RX, TX
int status = WL_IDLE_STATUS;
unsigned long lastSend;
// initialize serial for debugging
pinMode(11, OUTPUT);
analogReference(INTERNAL); // use the internal ~1.1volt reference | change (INTERNAL) to (INTERNAL1V1) for a Mega
dht.begin();
InitWiFi();
client.setServer( thingsboardServer, 1883 );
lastSend = 0;
status = WiFi.status();
if ( status != WL_CONNECTED) {
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(WIFI_AP);
// Connect to WPA/WPA2 network
status = WiFi.begin(WIFI_AP, WIFI_PASSWORD);
Serial.println("Connected to AP");
if ( !client.connected() ) {
reconnect();
if ( millis() - lastSend > 3000 ) { // Update and send only after 1 seconds
getAndSendTemperatureAndHumidityData();
getAndSendVoltageData();
lastSend = millis();
client.loop();
void getAndSendTemperatureAndHumidityData()
Serial.println("Collecting temperature data.");
// Reading temperature or humidity takes about 250 milliseconds!
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
String temperature = String(t);
String humidity = String(h);
// Just debug messages
Serial.print( "Sending temperature and humidity : [" );
Serial.print( temperature ); Serial.print( "," );
Serial.print( humidity );
Serial.print( "] -> " );
// Prepare a JSON payload string
String payload = "{";
payload += "\"temperature\":"; payload += temperature; payload += ",";
payload += "\"humidity\":"; payload += humidity;
payload += "}";
// Send payload
char attributes[100];
payload.toCharArray( attributes, 100 );
client.publish( "v1/devices/me/telemetry", attributes );
Serial.println( attributes );
/////////////////// DOOR MIJ TOEGEVOEGD ///////////////////
void getAndSendVoltageData()
total = 0; // reset
analogRead(A0); // one unused reading to clear any ghost charge
for (int x = 0; x < 64; x++) { // 64 analogue readings for averaging
total = total + analogRead(A0); // add each value
voltage = total * 0.0002505; // convert readings to volt | ---calibrate by changing the last three digits---
//Serial.print("The battery is ");
Serial.println(voltage, 2); // change to (voltage, 3) for three decimal places
//Serial.println(" volt");
if (voltage <= 12 )
digitalWrite (buzzer, HIGH);
Serial.println("BEEP");
digitalWrite (buzzer, LOW);
Serial.println("NO BEEP");
delay(200); // readout delay
payload += "\"voltage\":"; payload += voltage;
payload += "}";
// Send payload
void InitWiFi()
// initialize serial for ESP module
soft.begin(9600);
// initialize ESP module
WiFi.init(&soft);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
Serial.println("Connecting to AP ...");
// attempt to connect to WiFi network
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Connecting to ThingsBoard node ...");
// Attempt to connect (clientId, username, password)
if ( client.connect("Arduino Uno Device", TOKEN, NULL) ) {
Serial.println( "[DONE]" );
Serial.print( "[FAILED] [ rc = " );
Serial.print( client.state() );
Serial.println( " : retrying in 5 seconds]" );
// Wait 5 seconds before retrying
delay( 5000 );
