Keep reading soundsensor during the entire loop
Hi Guys,
At the moment i'm trying to build something like a policecar. My idea is to let hem just drive around and that works fine. But what i want to add next is that when i clap or make some other hard noise the policecar starts doing something else.
So far i figured out how to do that but there is 1 problem. What i want is de policecar to go back to normal when i clap again.
In short Policecar should start at status1, when i clap change to status2 and when i clap again go back to status1.
I have been searching for similar codes but can't find anything that i understand.
Hope you guys can help me (my current code is below).
int stat = 0;
  pinMode(12, OUTPUT); // Blue LED
  pinMode(13, OUTPUT); // Red LED
  int sound = analogRead(A5); // A5 is sound detector
  Serial.println(sound);
  delay(10);
  normal();
  police();
void normal(){
  if (stat%2 == 0){
    if (sound > 25){
      stat = stat + 1;
      delay(200);
    else {
      digitalWrite(13, HIGH);
      digitalWrite(13, LOW);
void police(){
  if (stat%2 == 1){
    if (sound > 25){
      stat = stat + 1;
      delay(200);
    else{
      digitalWrite(12, HIGH);
      digitalWrite(12, LOW);
Read the sound sensor each time through loop() and change the state when a sound is detected but do not use delay() anywhere as it blocks program execution during the delay() period.
See Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
UKHeliBob:
Speaking of which, is there "standard" State Machine tutorial to which newbies should be pointed?
UKHeliBob:
Thanks! It took some time before I understand how it worked but now it finally works!
gfvalvo:
I'd be inclined to write one if you think there's enough interest.
Hold that thought and have a look here, State Machine and Timers, Medium level tutorial.
... another state machine link from arduino.cc's Uncle Mike (Grumpy_Mike).
