Keeping an LED on for 3 seconds
hello im brand new to arduino and ive been tasked with creating a code that turns on an LED depending on what i type in the serial monitor. it works but i want them to stay on for 3 seconds before turning off, can anyone help me?
heres my code
int LEDRedPin = 5;
int LEDYellowPin = 3;
int LEDGreenPin = 4;
int LEDWhitePin = 2;
  pinMode(LEDRedPin, OUTPUT);
  pinMode(LEDYellowPin, OUTPUT);
  pinMode(LEDGreenPin, OUTPUT);
  pinMode(LEDWhitePin, OUTPUT);
void toggleLED (int LEDPin)
  digitalWrite(LEDPin, !digitalRead(LEDPin));
  if (Serial.available() > 0)
    int inByte = Serial.read();
    switch (inByte)
      case 'R':
        toggleLED(LEDRedPin);
       case 'Y':
        toggleLED(LEDYellowPin);
       case 'G':
        toggleLED(LEDGreenPin);
       case 'W':
        toggleLED(LEDWhitePin);
       default:
        digitalWrite(LEDRedPin, LOW);
        digitalWrite(LEDYellowPin, LOW);
        digitalWrite(LEDGreenPin, LOW);
        digitalWrite(LEDWhitePin, LOW);
If controlling only one led at the time is acceptable, just add delay(3000) after each toggle
Hello ausalmon
Yes, I have added a delay() function to your sketch.
Using the delay() function is a quick and easy, but unsightly addition.
Normally each letter would need its own 3 second timer.
Just try it out and play around.
int LEDRedPin = 5;
    switch (inByte)
      case 'R':
      case 'Y':
      case 'G':
      case 'W':
      default:
        delay(3000);
Is this homework?
Put this, inside the close brace for the if...
    delay(3000);
Try the following sketch:
#define R 5
#define Y 3
#define G 4
#define W 2
  pinMode(R, OUTPUT);
  pinMode(Y, OUTPUT);
  pinMode(G, OUTPUT);
  pinMode(W, OUTPUT);
    char inChar = Serial.read();
    switch (inChar)
      case 'R':
        turnOn(R);
      case 'Y':
        turnOn(Y);
      case 'G':
        turnOn(G);
      case 'W':
        turnOn(W);
      default:
        digitalWrite(R, LOW);
        digitalWrite(Y, LOW);
        digitalWrite(G, LOW);
        digitalWrite(W, LOW);
void turnOn(byte n)
  digitalWrite(n, HIGH);
  delay(3000);
  digitalWrite(n, LOW);
Here's a start, don't have time to finish, feel confident you can. :grin:
unsigned long
  redTimer,
  yellowTimer,
  greenTimer,
  whiteTimer;
int onTime = 3000;
const byte
  LEDRedPin = 5,
  LEDYellowPin = 3,
  LEDGreenPin = 4,
  LEDWhitePin = 2;
  Serial.begin(9600); // set Serial Monitor to Newline
  delay(3000);
  static char inChar = '\n';
  if(Serial.available() > 0)
    if(inChar == '\n'){};
  switch (inChar)
    case 'R':
    redTimer = millis();
       // more cases...
  digitalWrite(LEDRedPin, millis() - redTimer < onTime);
      // more digitalWrites...
