Sketch generated by the Arduino IoT Cloud Thing "BeeControl"
https://create.arduino.cc/cloud/things/80c3d7dd-2fcd-4d7d-947b-ada8a7616f52
Arduino IoT Cloud Properties description
The following variables are automatically generated and updated when changes are made to the Thing properties
float t;
float h;
Properties which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
pinMode(LED_BUILTIN, OUTPUT);
dht.begin();
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
float h = dht.readHumidity();
float t = dht.readTemperature();
Serial.print("Luftfeuchte: ");
Serial.print(h);
Serial.print("% Temperatur: ");
Serial.print(t);
Serial.println("°C ");
