Keine Verbindung zum Board
Hallo
Habe mir vor ein paar Tagen ein Startpaket von Sunfounder mit dem Ardunio Board R3 zugelegt. Die Software habe ich runtergeladen von Arduino Download. Den Com Port eingestellt. Das Board gewählt. Danach das Board an den PC angeschlossen. (Windows Version 7). Das Program "Blink" geladen. Bei dem Komilieren erhalte ich die Meldung:
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files\Arduino\hardware" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Users\Ira\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\Users\Ira\AppData\Local\Temp\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Ira\Documents\Arduino\Blink\Blink.ino"
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files\Arduino\hardware" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Users\Ira\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\Users\Ira\AppData\Local\Temp\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Ira\Documents\Arduino\Blink\Blink.ino"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Ira\AppData\Local\Temp\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp\sketch\Blink.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Ira\AppData\Local\Temp\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp\sketch\Blink.ino.cpp" -o "C:\Users\Ira\AppData\Local\Temp\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
open NUL: Das System kann die angegebene Datei nicht finden.
Fehler beim Kompilieren für das Board Arduino/Genuino Uno.
das wars weiter komme ich nicht
was habe ich falsch gemacht?
Was ist das für ein Board?
Hast du außer USB noch etwas anderes angeschlossen?
Welche IDE-Version verwendest du?
Den Fehler kriegst du vermutlich schon beim Verifizieren, egal ob ein Uno oder gar nichts angeschlossen ist?
Windows Version 7 : 64 Bit vermutlich?
Ich hab die IDE (ich verwende noch 1.6.7) bei den 32-Bit Programmen installiert und für jede Version einen Unter-Ordner:
C:\Program Files (x86)\Arduino\1.6.7\
[nachtrag]
Die windows .exe Installation will meine alte version 1.0.6 runterschmeissen, daher will ich sie nicht, sondern verwende die zip - Version.
Hast Du versucht dan PC auszuschalten un neu zu starten?
Grüße Uwe
Hallo der Fehler ist doch klar. Du hast die Software unter C:\Program Files (x86)\Arduino\1.6.7\ installiert. Die IDE sucht den Compiler aber unter C:\Program Files\Arduino. Entweder neu installieren oder den Pfad des AVR dude in C:\Users\Benutzer\AppData\Local\Arduino15\preferences anpassen.
So einfach ist es leider nicht:
Ich habe Arduino in  C:\Program Files (x86)\Arduino\1.6.7\
Uwe_ausBayern hat die Version 1.6.9 in  C:\Program Files\Arduino\
Dort wird sein avr-g++ auch gefunden
Hallo
Erstmal besten Dank für eure Antworten
Ich werde versuchen alle Fragen zu beantworten. Als erstes
Frage: von HotSystems
Antwort:
Ich habe ein UNO R3 Board
Ich habe nicht anderes angeschlossen nur über USB das Board.
Die Version 1.6.9
Frage: von Michael_X
Antwort: Genau, ich erhalte die oben aufgeführte Fehlermeldung auch dann, wenn ich kein UNO Board angeschlossen habe und nur das Program Arduino starte und den Sketch Blink kompiliere
Frage von uwefed
Antwort: Ja mehrfach, leider keinen Erfolg
Um jede Antwort zu meinem Problem bin ich Dankbar
Ich würde in dem Fall die IDE (Programm) deinstallieren und neu installieren. Da ist sicher etwas schief gelaufen.
Übrigens, herzlich willkommen im Forum.
Super, dass du ungefragt Fehlermeldungen postest, und sie sogar nachträglich noch durch code-Tags lesbar machst. [Ahem: Das war Uwe ! ;)]
Vermutlich gibt es bei dir das Zwischenergebnis
%TEMP%\buildd5c4b0093dd117dfa33ef4910e564ebc.tmp\preproc\ctags_target_for_gcc_minus_e.cpp
nicht
Zum Vergleich bei mir:
C:\Program Files (x86)\Arduino\1.6.7\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\1.6.7\hardware" -hardware "C:\Users\michaelh\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\1.6.7\tools-builder" -tools "C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\1.6.7\libraries" -libraries "C:\Users\michaelh\Documents\Arduino\libraries" -fqbn=arduino:avr:Standalone328_12 -ide-version=10607 -build-path "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\1.6.7\examples\01.Basics\Blink\Blink.ino"
C:\Program Files (x86)\Arduino\1.6.7\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\1.6.7\hardware" -hardware "C:\Users\michaelh\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\1.6.7\tools-builder" -tools "C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\1.6.7\libraries" -libraries "C:\Users\michaelh\Documents\Arduino\libraries" -fqbn=arduino:avr:Standalone328_12 -ide-version=10607 -build-path "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\1.6.7\examples\01.Basics\Blink\Blink.ino"
"C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\variants\standard" "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\sketch\Blink.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\variants\standard" "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\sketch\Blink.ino.cpp" -o "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\1.6.7\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\variants\standard" "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\sketch\Blink.ino.cpp" -o "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\sketch\Blink.ino.cpp.o"
"C:\Program Files (x86)\Arduino\1.6.7\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=12000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\variants\standard" "C:\Program Files (x86)\Arduino\1.6.7\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\michaelh\AppData\Local\Temp\build6c355214f958542a2b57f25ff3f53f7e.tmp\core\wiring_pulse.S.o"
Statt direkt tief einzusteigen ist Neuistallation bestimmt einfacher
Hallo
Besten Dank für die Tip´s
Wie empfohlen habe ich das Program deinstalliert alle Orner gelöscht und dann aus dem Windows Installer einen download gemacht. Board und com Port eingestellt. Den Sketch "Blink" geladen und kompiliert und erhielt die gleiche Fehlermeldung wie oben dargestellt.
Rechner runter und hochgefahren keine Veränderung
Jetzt habe ich wieder alles gelöscht und noch mals das Program aus dem Windows Zip down geladen. Alles eingestellt und leider wieder die gleiche Fehlermeldung wie oben dargestellt erhalten.
Jetzt stehe ich blöd da und bitte weiter um Hilfestellung
Besten Dank
Ich habe einen Laptop mit englischem Windows 8.1 (64 bit)
Ich habe mir von arduino.cc die Windows zip geholt und auf mein zweites Laufwerk nach D:\Arduino entpackt. (Um mit dem ganzen Administrator-Gedöns nichts zu tun zu haben.)
Dann habe ich im Explorer die Datei D:\Arduino\arduino-1.6.9\arduino.exe doppelgeklickt. Ist gestartet und hat Version 1.6.9 angezeigt.
Habe bei File / Examples - Basic - Blink ausgewählt
Habe Verifizieren geklickt : OK
Habe bei Preferences - Language auf Deutsch gestellt und arduino.exe beendet
Neu gestartet: Werkzeuge - Board Genuino Uno ausgewählt
Sketch - Überprüfen/Kompilieren Ctrl-R ausgewählt : OK
Hallo erstmal besten Dank, speziell an Michel_x für die Antwort.
Hier die Zusammenfassung was ich unternommen habe:
Ich habe mir von arduino.cc die Windows zip geholt und auf mein Wechsellaufwerk nach F:\Arduino entpackt.
Dann habe ich im Explorer die Datei F:\Arduino\arduino-1.6.9\arduino.exe doppelgeklickt. Ist gestartet und hat Version 1.6.9 angezeigt.
Habe Verifizieren geklickt : und leider die Fehlermeldung wie oben beschreiben erhalten
Sketch - Überprüfen/Kompilieren Ctrl-R ausgewählt : und leider die Fehlermeldung wie oben beschreiben erhalten
Bei angeschlossenen Board kann ich die Boardkennung einsehen, dass bedeutet doch, dass ich eine Verbindung zum Board zustande bekomme. Nur leider läuft das Arduinoprogram nicht so richtig.
Hier die Angaben zu meinem Rechner:
Laptop von Dell Inspiration N 5030 mit windows 7 home premium service pack 1 32 bit version.
Mit der Bitte um Hilfestellung. Oder sollte ich mir gleich einen Mac zulegen?
Auf keinen Fall einen Mac! oder gar Ubuntu!
:wink:
Mal angenommen, an den Programmdateien liegt es nicht. Dann ist bei einer der früheren Installationen in deinen Benutzerspezifischen Sachen was schief gelaufen.
C:\Users<deinKonto>\AppData\Roaming\Arduino putzen ...
