Key bounce code help needed
Can anyone explain why this passes 2 key events before waiting on bounce wait?
I press a key and I get a repeat of it before it starts waiting for the counter.
void checkKey(void) {
  if (stop_bounce) {
    bounce++;
    if (bounce > 30) {
      stop_bounce = false;
      bounce = 0;
    return;
    if (digitalRead(key1) == LOW) {
      bounce = 0;
      stop_bounce = true; // got a press so lets not accept anymore for a while
      keycode = 1;
      Serial.println(F("K1"));
void scanKey(void) {
  //check keys
  checkKey();
  if (keycode == 1) {
    lights_out();
    switch (state) {
      case dark:
        Serial.println(F("to idle state"));
        state = idle;
      case idle:
        Serial.println(F("to dark state"));
        state = dark;
      default:
        if (state > idle) {
          state = idle;
    keycode = 0;
    stop_bounce = true;
There is no bounce_wait or bouncewait or bounceWait in your partial display of your sketch.
Debounce uses a timer, and here, millis() is usually suggested... link
stop_bounce is a bool. When checkKey is called the state of stop_bounce either allows a read from the key pin or not. It Not.. it increments a counter and once that counter hits 31, stop_bounce is set to false so the next time checkKey is called, the key pin can be read again. The sub should have to be called 30 times before allowing another key pin test, For some reason, it is allowing keycode to be set to 1, 2 times before stop_bounce is true. Hope that's understandable. I suck at translation of thought. :slight_smile:
Here is all of the Sketch. I built a StarGate that is pretty amazing. All the code works but the key repeating before reading is blocked. Think I will try a timer and not a counter.
Any recommendations on this code?
#include <SoftwareSerial.h>
#define FASTLED_ALLOW_INTERRUPTS 1
#include <FastLED.h>
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define rxPin 10
#define txPin 5
SoftwareSerial nanoPort(rxPin, txPin);
int master_vol = 20;//bigger = quieter
// key pins
#define key1 A5
// define the pins used
#define CLK 13       // SPI Clock, shared with SD card
#define MISO 12      // Input data, from VS1053/SD card
#define MOSI 11      // Output data, to VS1053/SD card
#define SHIELD_RESET  8      // VS1053 reset pin (unused!)
#define SHIELD_CS     6      // VS1053 chip select pin (output)
#define SHIELD_DCS    7      // VS1053 Data/command select pin (output)
#define CARDCS 9     // Card chip select pin
#define DREQ 2       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
// led pins
#define DATA_PIN_CHEVS A0 // StarGate 9 led data
#define DATA_PIN_GATE A1 // StarGate 134 led data
#define DATA_PIN_BACKLIGHT A3 // back lighting 9 leds
#define NUM_LEDS_CHEVS 9
#define NUM_LEDS_GATE 133
#define NUM_LEDS_BACKLIGHTING 9
// Define the array of leds
CRGB leds_chevs[NUM_LEDS_BACKLIGHTING];
CRGB leds_gate[NUM_LEDS_GATE];
CRGB leds_backlighting[NUM_LEDS_BACKLIGHTING];
byte out_data[3];
byte data_in;
byte keycode = 0;
byte bounce;
byte led_index = 0;
byte led_shift_gate = 0;
byte current_addy;
byte next_addy;
byte p_pnt = 0;
byte stop_bounce = false;
unsigned long openGateTimer = 0;
float current_angle = 0.0;
boolean stepperBusy = false;
boolean activate = false;
boolean activating = false;
boolean flip = false;
boolean waitForFx = false;
// out commands
#define RUNTOFORWARD 100
#define RUNTOBACKWARDS 101
#define SHUTMOTOROFF 2
// in commands
#define RUNCOMPLETE 42
#define ACK 41
  Serial.println(F("Reset"));
  nanoPort.begin(9600);
  if (! musicPlayer.begin()) { // initialise the music player
    Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
    while (1);
  musicPlayer.setVolume(200, 200); // shut it off
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  //  shutOffChevs();
  //  shutOffGate();
  //  shutOffBack();
  // Set up key
  pinMode(key1, INPUT_PULLUP);
// subs //----------------------------------------------------------------
void convertToArray(byte code, int val) {
  out_data[0] = code;
  byte b1 = val & 255;
  byte b2 = (val & 65280) / 256;
  out_data[1] = b1;
  out_data[2] = b2;
void dialAddress(void) {
  static byte p_address[] = {26, 6, 14, 31, 11, 29, 0}; //abydos default
  if (p_pnt == 7) {
    return;
  if (p_pnt == 0) {
    shutOffChevs();
  //  Serial.println("playing");
  next_addy = p_address[p_pnt] ;
  //Serial.println(next_addy);
  int s = 100 * current_addy;
  int d = 100 * next_addy;
  int v = d - s;
  if (v < 0) {
    out_data[0] = RUNTOBACKWARDS;
    out_data[0] = RUNTOFORWARD;
  stepperBusy = true;
  convertToArray(abs(v));
  nanoPort.write(out_data, 3);
  current_addy = next_addy;
  play("fx/roll.mp3", 10 + master_vol);
  //  while ( ! musicPlayer.playingMusic ) {} // Make sure it starts
  delay(120);
  FastLED.addLeds<WS2812B, DATA_PIN_CHEVS, RGB>(leds_chevs, NUM_LEDS_CHEVS);
  leds_chevs[0] = CHSV(96, 255, 255);
  leds_chevs[8] = CHSV(96, 255, 255);
  leds_chevs[4] = CHSV(96, 255, 255);
  FastLED.show();
  back_FO(96, 255);
//states the app can be running in
#define dark 0
#define idle 1
#define warning 2
#define wait_alarm 3
#define dialing 4
#define activate 5
#define openinggate 6
#define gateopen 7
#define gateclosing 8
#define gateclosed 9
// start off with color changing lights
byte state = idle;
  static byte hue = 0;
  // triggers events and sound
  // There are 10 possible states during the operation.
  // Setting state to 1 starts the dialing process and show.
  switch (state) {
    case dark:
      // nothing is happening. Lights are off.
    case idle:
      // the show may have been canceled so read off any pending data
      if (nanoPort.available()) {
        Serial.println("nano data available");
        data_in = nanoPort.read();
      p_pnt = 0; // this is the current dialling address. Reset it!
      waitForFx = false; // incase we canceled and its waiting for FX to stop playing.
      // if music is playing after cancel, stop it NOW!
      if (musicPlayer.playingMusic) {
        musicPlayer.stopPlaying();
      // idle mode so lets do some lighting :)
      Spiral_sine(hue, -1, 16);
      back_FO(hue, 255); // all leds at that colar at that level.
      chevs_FO(hue, 255); // all leds at that colar at that level.
    case warning:
      shutOffChevs();
      shutOffGate();
      shutOffBack();
      play("fx/alarm.mp3",  master_vol);
      delay(50); // time to start playing
      waitForFx = true;
      Serial.println("Warning");
      state = wait_alarm;
    case wait_alarm:
      back_FO(96, hue);
      hue += 1;
    case dialing:
        if (data_in == RUNCOMPLETE) {
          //dialed all chevrons so lets setup for ativatie sequence.
          if (p_pnt == 6) {
            state = activate;
            playChevronLocked(); // Set leds, play lock fx and waits to get done playing
            waitForFx = true;
            p_pnt = 0;
            state = activate;
            //            Serial.println(F("RUNCOMPLETE"));
            //            Serial.println(p_pnt);
      if (state == dialing) {
        if (! stepperBusy) {
          dialAddress();
    case activate:
    case openinggate:
      //shake it up
      back_random_levels(1, true);
      quake();
    case gateopen:
      Spiral_sine(185, -1, 16);
      back_random_levels(185, false);
    case gateclosing:
      //shake it up
      quake();
  // wait for FX sound to finish playing and move on
  if (waitForFx) {
    if (! musicPlayer.playingMusic) {
      switch (state) {
        case wait_alarm:
          state = dialing;
        case dialing:
        case activate:
          play("fx/activate.mp3", 10 + master_vol);
          //          Serial.println("fx/activate.mp3");
          state = openinggate;
          activating = true;
          waitForFx = true;
          led_index = 0;
          delay(300);
        case openinggate:
          play("/fx/loop.mp3", 0 + master_vol);
          delay(200); // synch light start
          waitForFx = true;
          state = gateopen;
        case gateopen:
          play("fx/close.mp3", 10 + master_vol);
          waitForFx = true;
          state = gateclosing;
        case gateclosing:
          state = gateclosed;
          waitForFx = false;
          state = idle;
  hue++;
  scanKey();
}//loop
void play(String s, int v) {
  musicPlayer.startPlayingFile(s.c_str());
  musicPlayer.setVolume(v, v);
  Serial.print("playing :");
  Serial.println(s);
void playChevronLocked(void) {
  static byte chev_index[] = {3, 2, 1, 7, 6, 5, 4};
  //      Serial.println("lock playing");
  byte cv = p_pnt + 1;
  String t = "fx/chevron" + String(cv) + ".mp3";
  //  t = "fx/loop.mp3";
  play(t, 10 + master_vol);
  delay(200);
  leds_chevs[0] = CHSV(255, 0, 255);
  leds_chevs[8] = CHSV(255, 0, 255);
  leds_chevs[4] = CHSV(96, 255, 0);
  leds_chevs[chev_index[p_pnt]] = CHSV(192, 255, 255);
  FastLED.show();
  //Serial.println(musicPlayer.currentTrack );
  back_FO(185, 255);
  while (musicPlayer.playingMusic);
  p_pnt += 1;
  if (stop_bounce) {
    bounce++;
    if (bounce > 30) {
      bounce = 0;
    return;
      bounce = 0;
      keycode = 1;
  //check keys
  checkKey();
  if (keycode == 1) {
    lights_out();
    switch (state) {
      case dark:
        state = idle;
      case idle:
        state = dark;
      default:
        if (state > idle) {
          state = idle;
    keycode = 0;
    stop_bounce = true;
void lights_out(void) {
  shutOffChevs();
  shutOffGate();
  shutOffBack();
void Spiral_sine(int color, int dir, int scaler) {
  FastLED.addLeds<WS2812B, DATA_PIN_GATE, RGB>(leds_gate, NUM_LEDS_GATE);
  //Serial.println(led_index);
  float pi = 3.14159;
  float p = pi * scaler / 133.0;
  float cur_ang = 0;
  float j = random(255) / 255; //0 to 1
  if (state == gateopen) {
    color += random(10);
  for (int i = 0; i < NUM_LEDS_GATE; i++) {
    int sine_val = sin(cur_ang + pi / 2.0) * 127;
    //sine_val = min(sine_val, led_index * 28);
    cur_ang += p;
      sine_val *= j;
      leds_gate[ check_overflow_gate(i + led_shift_gate * dir) ] = CHSV(color, 255, sine_val + random(125));
      leds_gate[ check_overflow_gate(i + led_shift_gate * dir) ] = CHSV(color, 255, sine_val + 127.5);
  FastLED.show();
  led_shift_gate++;
  if (led_shift_gate >= NUM_LEDS_GATE) {
    led_shift_gate = 0;
//led_shift_gate rollover check
int check_overflow_gate( int n) {
  if (n >= NUM_LEDS_GATE) {
    return n - NUM_LEDS_GATE;
  if (n < 0) {
    return n + NUM_LEDS_GATE;
  return n;
void back_FO(int color, byte level) {
  FastLED.addLeds<WS2812B, DATA_PIN_BACKLIGHT, RGB>(leds_backlighting, NUM_LEDS_BACKLIGHTING);
  for (int i = 0; i < NUM_LEDS_BACKLIGHTING; i++) {
    leds_backlighting[i] = CHSV(color, 255, level);
  FastLED.show();
void chevs_FO(int color, byte level) {
  for (int i = 0; i < NUM_LEDS_CHEVS; i++) {
    leds_chevs[i] = CHSV(color, 255, level);
  FastLED.show();
void shutOffChevs(void) {
    leds_chevs[i] = CRGB::Black;
  FastLED.show();
void shutOffGate(void) {
    leds_gate[i] = CRGB::Black;
  FastLED.show();
void shutOffBack(void) {
    leds_backlighting[i] = CRGB::Black;
  FastLED.show();
void back_random_levels(int color, boolean W) {
  if (W) {
      leds_backlighting[i] = CHSV(255, 0, random(255));
      leds_backlighting[i] = CHSV(color, 255, random(255));
  FastLED.show();
void quake() {
  int r = random(255);
    leds_gate[i] = CHSV(185, led_index, r);
  led_index += 2;
  FastLED.show();
void wave_134(int color, boolean W) {
  int v = (sin(current_angle) + 1) * 127.4;
  //Serial.println(v);
  if (W) {
      leds_gate[i] = CHSV(255, 0, v);
      leds_gate[i] = CHSV(color, 255, v);
  FastLED.show();
void convertToArray(int val) {
  out_data[1] = b1;
  out_data[2] = b2;
Have you tried with over "30"? Like 100? 75? (you should give that a #define name)
Yes but what's weird is if I hold the key down, I reads 2 times and then waits and than reads 2 times.. It reads 2 times ever time it is allows to read the key pin. So ODD!
I have checked that I am not using the the variables anywhere else that I should not.
Does this need to start as true?
because, as false the first time testing "if (stop_bounce)" fails.
False. It wont read for 30 calls if True.
If you are using true/false, make type = boolean.
oh man... How'd I miss that!?
Thanks!
Same behavior :frowning:
I don't get it.
I fixed this.. It could never start the dialing process.
    switch (state) {
      case dark:
        Serial.println(F("to idle warning"));
        state = warning;
And it still reads 2 times.
Starts as Idle.. Press a key It goes to dark and than to play mode It should only changed to dark mode after a press and than to warning mode after a 2nd press but.. I get this.
21:33:20.023 -> K1
21:33:20.070 -> to dark state
21:33:20.070 -> K1
21:33:20.070 -> to idle warning
21:33:20.162 -> playing :fx/alarm.mp3
This is not in your posted code. You only have "to dark state" and "to idle state"... you have a "warning" but not preceded by "to idle "
I know you don't want to check my other suggestion, but you are using a different sketch than what you are showing. I pointed that out twice. Enjoy the ride.
Insane.. I had the bounce counter as a byte. Any setting > 255 would do nothing as it to small to store it. I changed it to an int and jacked the number to 4000. It worked but too long a delay. 2k feels better.
In dark state.. there is zero loading on the processor and loop is near instant. It calls that sub thousands of times a second.
Thanks for the input. Your first idea was the correct one after all!
