I have written some code that is looking for a 4 digit code. If the code is incorrect a two tone buzzer will play and allow you to enter another code. If the correct code is entered it will power a relay. That part all works great.
I also have another part of the code that is monitoring a door sensor that is normally closed. When the door opens I want the LED strip to power on regardless of if the door closes and opens again. I want the LEDs to go off and stay off when the correct code is entered.
My code turns the LEDs off when the correct code is entered but then they turn back on after 5 seconds. Any suggestions?
#include <Keypad.h>//include library code
#include "pitches.h"//include library code
// Melodies definition: rejection - you can change melodies. see in file pitches.h
int keypadRead; // keypad read 1 = good, 0 = bad for playTune function
int noaccess_melody[] = {NOTE_C5, NOTE_C4};
int noaccess_noteDurations[] = {2};
const int buzzerPin = 12; //active piezo buzzer
int doorPosition = 13; //Door position sensor. N.C. when safe door is closed
int led = 11; //LED strip inside safe
const int correctPass_relay = 10; //relay that triggers when correct password is entered
#define Password_Lenght 5 //give enough room for 8 chars + NULL char
char Data[Password_Lenght]; //8 is the number of chars it can hold + the null char = 9
char Master[Password_Lenght] = "1234";//default password is 1234
byte data_count = 0; //variable to store the number counting
const byte rows = 4; //four rows
const byte cols = 3; //three columns
char keys[rows][cols] = {//define the symbols on the buttons of the keypads
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'#', '0', '*'}
byte rowPins[rows] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[cols] = {5, 4, 3}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, rows, cols );
pinMode(buzzerPin, OUTPUT); //sets buzzerPin as OUTPUT
pinMode(doorPosition, INPUT_PULLUP); //tells when safe door is open
pinMode(led, OUTPUT); //output for LED strip inside safe
pinMode(correctPass_relay, OUTPUT); //relay OUTPUT triggers with correct password
Serial.begin(9600); //initialise the serial communication at 9600 bps
Serial.println("********************");
Serial.println("*****Electronic*****");
Serial.println("*****Keypad Lock****");
Serial.println("*****Enter code*****");
char customKey = customKeypad.getKey();//reads the key pressed
if (customKey) // makes sure that the key is actually pressed
Data[data_count] = customKey; // store char into data array
Serial.print(customKey); // print char at said cursor
data_count++; // increment data array by 1 to store new char, also keep track of the number of chars entered
if (digitalRead(doorPosition) == LOW) {
digitalWrite (led, HIGH); //Turns LEDs inside safe ON when safe door is open
if (data_count == Password_Lenght - 1) // if the array index is equal to the number of expected chars, compare data to master
if (!strcmp(Data, Master)) {
keypadRead = 1;
digitalWrite(led, LOW); //Turns LEDs inside safe OFF when puzzle is solved
digitalWrite(correctPass_relay, HIGH);//relay is on
Serial.println("");
Serial.println("** ACCESS GRANTED **");
Serial.println("** WELCOME!! **");
delay(5000);//sets delay for 5 seconds
digitalWrite(correctPass_relay, LOW);//relay is off
resetAll ();//reset all function
else {
keypadRead = 0;
playTune(keypadRead);
Serial.println("");
Serial.println("** ACCESS DENIED! **");
Serial.println("** INVALID CODE **");
void resetAll ()
while (data_count != 0)
Data[data_count--] = 0; //clear array for new data
return;
//Function to play the melody during No access
void playTune(int Scan) {
if (Scan == 0) // Wrong secret code entered - No Access
for (int i = 0; i < 2; i++) //loop through the notes
int noaccess_noteDuration = 1000 / noaccess_noteDurations[i];
tone(buzzerPin, noaccess_melody[i], noaccess_noteDuration);
int noaccess_pauseBetweenNotes = noaccess_noteDuration * 1.30;
delay(noaccess_pauseBetweenNotes);
noTone(buzzerPin);
