Key Switch with an Arduino
Hey guys - Thanks in advance for your help. This forum community has guided me well in terms of knowledge and helpfulness. I'm trying to have a key switch, tabular solenoid and a (push) limit switch connected as an input to certain pins on an arduino. I have been told I need a solenoid driver or a relay. The key sw, limit sw and solenoid are from RobotShop:
Solenoid:
http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Spa-647&lang=en-US
Key Sw:
http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Ite-01&lang=en-US
Limit Sw:
http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Tam-71&lang=en-US
PS I use RobotShop as I am in Canada.
Thanks guys ! I appreciate this !
Questions generally end with a ?. Did you have one?
akashroy:
I don't see how you would connect a solenoid as an input.
akashroy:
If the solenoid is to be an output then yes: to drive a solenoid, you need some sort of driver circuit. It can be done quite simply and there are plenty of examples on this site. Or, you may be able to use a motor drive shield if you can find one that can support the voltage and current needed by the solenoid.
