Hello, I'm actually preparing a code which will be used to get informations from a 3*4 keypad, to compare them with a written password, and then write a message on a LCD screen.
My problem is that I have the following error message :
exit status 1 'key' was not declared in this scope
So I'm wondering why this message appears, because I followed This tutorial (click)
But I still have the same problem. So I'm posting the code with the message, I hope someone could help me.
Thanks in advance
The code :
#include <Keypad.h>
#include <Password.h>
#include <Deuligne.h>
Deuligne lcd;
const byte ROWS = 4; //Création de 4 lignes
const byte COLS = 3; //Création de 3 colonnes
char keys[ROWS][ROWS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'#','0','*'} //Représentation informatisée du clavier achevée
byte rowPins[ROWS] = {5, 4, 3, 2}; //Connexion des lignes sur les broches 5, 4, 3 & 2 de l'Arduino
byte colPins[COLS] = {8, 7, 6}; //Connexion des lignes sur les broches 8, 7 & 6
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Password password = Password("2703");
lcd.init();
lcd.clear();
lcd.backLight(true);
lcd.noCursor();
lcd.setCursor(0,0); //Fait en sorte d'écrire le message au début de l'afficheur
lcd.print("Entrez le code"); //Affiche le message "Entrez le code"
char getKey(); //Reçoit la valeur du bouton pressé
if (key != NO_KEY){
Serial.println(key); //Si le bouton pressé n'est pas égal à "aucun bouton pressé", alors on l'affiche
String keyOne = keypad.waitForKey();
String keyTwo = keypad.waitForKey();
String keyThree = keypad.waitForKey();
String keyFour = keypad.waitForKey();
//Reconnait les valeurs tapées sur le clavier
String pwd = keyOne + keyTwo + keyThree + keyFour; //Assemble les valeurs pour créer un nombre à quatre chiffres
Serial.println(pwd); //Affiche le code tapé
delay(2000); //Attends 2 secondes
if (pwd == 2703)
Serial.println ("Bienvenue")
delay(5000);
password.reset();
if (pwd != 2703)
Serial.println ("Code faux")
delay(2000);
Serial.println ("2 essais restants")
delay(2000)
password.reset()
Hello again, I made the code again, and now it's like this :
#include <Wire.h> //Intègre une librairie pour communiquer par une liaison spécifique, ici I2C
#include <Keypad.h> //Intègre une librairie pour un clavier matriciel
#include <Password.h> //Intègre une librairie pour simplifier la gestion du mot de passe
#include <Deuligne.h> //Intègre une librairie pour une bonne utilisation de l'afficheur Deuligne
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); //Création du clavier
Deuligne lcd;
keypad.addEventListener(keypadEvent); //Crée un évènement pour le clavier (ici, l'affichage d'un message)
Wire.begin(); //Ajoute une liaison I2C
lcd.init(); //Initialise l'afficheur
lcd.clear(); //Efface les éventuelles valeurs
lcd.setCursor(0,0); //Écrit en haut à gauche
lcd.print("Config"); //Affiche un sample visuel pour voir si la disposition du texte est correcte
lcd.setCursor(7,0); //Écrit au milieu de la ligne du haut
lcd.print("Ok"); //Deuxième sample test
keypad.getKey();
void keypadEvent(KeypadEvent eKey) {
switch (keypad.getState()) { //Prévoit une action en fonction de la valeur finale
case PRESSED:
Serial.print("CHIFFRE: ");
Serial.println(eKey);
switch (eKey) {
case '*': checkPassword(); break; //Action 1 : Quand * est pressé, le code tapé est vérifié
case '#': password.reset(); break; //Action 2 : Quand # est pressé, le code tapé est réinitialisé
default: password.append(eKey); //Action 3 : Pour n'importe quelle touche, on retient les valeurs
void checkPassword() {
if (password.evaluate()) {
Serial.println("Bienvenue");
}else{
Serial.println("Code faux");
delay(2000);
Serial.println("Veuillez réessayer");
I don't have a single error message, except for an error which happens when I want to do a compilation, it tells me that there's an error during the compilation. What could it be? Thanks in advance
Post the full error (in code tags preferably). You can select all text in the (bottom) output window abd copy it; there might also be a button 'copy message' in the title bar of the output window (this might depend on version of the IDE).
Next paste it in your post (as said, preferably using code tags)
Arduino : 1.6.6 (Windows 7), Carte : "Arduino/Genuino Uno"
In file included from Z:\SIN\Programme_Final\Programme_Final.ino:4:0:
C:\Users\yan.pruvot\Documents\Arduino\libraries\Snootlab-Deuligne-c57bca6/Deuligne.h:68:16: error: conflicting return type specified for 'virtual void Deuligne::write(uint8_t)'
virtual void write(uint8_t);
In file included from C:\Program Files\arduino-1.6.6-windows\arduino-1.6.6\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
from C:\Program Files\arduino-1.6.6-windows\arduino-1.6.6\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
from C:\Program Files\arduino-1.6.6-windows\arduino-1.6.6\hardware\arduino\avr\cores\arduino/Arduino.h:224,
from sketch\Programme_Final.ino.cpp:1:
C:\Program Files\arduino-1.6.6-windows\arduino-1.6.6\hardware\arduino\avr\cores\arduino/Print.h:48:20: error: overriding 'virtual size_t Print::write(uint8_t)'
virtual size_t write(uint8_t) = 0;
Z:\SIN\Programme_Final\Programme_Final.ino:20:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
exit status 1
Erreur lors de la compilation.
Ce rapport contiendrait plus d'informations si l'option
"Montrer les informations de sortie pendant la compilation"
était activée dans Fichier > Préférences.
The write() method is declared virtual in the Print class. That means that any class, like Deuligne, that inherits from Print needs to implement the write() methods EXACTLY as Print defines them. The Deuligne class does not.
Years ago, the Print class changed the definition of the write() methods to require that they return the number of characters written, rather than returning nothing. You need to fix the Deuligne class to play by the new rules.
PaulS:
So you're telling me...I don't have the right Library and I need to add another one?
