Keyboard control from PC to Arduino
Hi everyone!
I want to control a motor from pc by assigning a key like "w". For example while I press "w" it will turn clock-wise. But it should be in real time, not like write "w" and press enter to make it work. It there any code I can do this? And also I want this to be wireless but not with bluetooth or wi-fi but probably with a good range transmitter/receiver. Do you have any advice how can I do it? I need to transfer data from arduino to pc and from pc to arduino simultaneously. For example while arduino sending me RPM of motor, I will be able to set the RPM by my pc.
Thanks, I hope you get what I mean :slight_smile:
You can do the "press a key and send it via serial" without the need to press return using a terminal emulator such as puTTY running on the PC or you could, of course, write something yourself in one of many languages, but I have no experience of wireless devices.
This question may be better in the Project Guidance section of the forum but please ask a moderator to move it rather than cross posting it there.
I can use C but I just dont know how to do what I want. Can you explain a little bit more?
Which end (Arduino or PC) have you got a problem with ?
You can use one of the examples in serial input basics to receive the data in the Arduino. Then you need a PC program that can send the data in a suitable format.
This Python - Arduino demo may give you some ideas. The general approach is applicable in any language.
...R
