Keyboard Control LED problem
I am a beginner in both programming and arduino. i am working on a project to drive a robot using inputs from a wireless keyboard. I am using a PC connected serially to the Arduino to transfer the key inputs to the dc motors. as a test run i connected the arduino to an LED and wrote the code to take the key input and turn the LED on and off. i would like to be able to press a key and have the LED light up and turn off when i release the key. so far the light turns on when i press the key and stays on until another key is pressed. i have tried inputting keystrokes from both hyperterminal and putty. any help would be greatly appriciated, my code is below
// variable to store serial data int incomingByte = 0;
void setup(){
// Start serial monitor at 9600 bps Serial.begin(9600);
// declare outputs pinMode(13, OUTPUT); pinMode(12, OUTPUT);
// turn LED Off by default digitalWrite(13, LOW);
void loop(){
// check for serial data if (Serial.available() > 0) { // read the incoming byte: incomingByte = Serial.read(); // if available, blink LED and print serial data received. digitalWrite(13, HIGH); // say what you got: Serial.print("I received: "); Serial.println(incomingByte); // delay 10 milliseconds to allow serial update time delay(10);
if (incomingByte == 'q' || incomingByte == 'Q')// keypress to turn on LED { digitalWrite(12, HIGH); } else digitalWrite(12, LOW);
Do you want to use a PC in the final design? If so, you are going to need to use a different program on the PC. You could write a Processing program to handle the different key states, and it would talk to the Arduino.
References: See keyboard section: http://www.processing.org/reference/ Using the serial port: http://learning.codasign.com/index.php?title=Communicating_with_Processing_Over_Serial
I was afraid of that, i have a feeling that is beyond my programming capacity at the moment. do you know of any GUI interfaces that other people have used for this type of an application. i have found a lot of people who are doing similar projects online.
