<Keyboard.h> lib question
hello.
I checked that there is no problem with the board with the example 'blink' using Arduino Leonardo.
Then I tested Keyboard.h and it failed, so I ask a question.
The sketch is below.
#include <Keyboard.h>
  Keyboard.begin();
  Keyboard.println("Hello!");
  delay(2000);
After uploading, 'avrdude done. Thank you.'
, and the Tx LED blinks every 2 seconds on the board. But in Notepad, 'Hello!' is not entered.
What is the cause?
Welcome to the forum
Which Arduino board are you using ?
Thank you :slight_smile:
The board is an Arduino Leonardo.
Basically your code works here. I modified it as I want to be able to stop the spamming.
const uint8_t safetyPin = A0;
  Keyboard.begin();
  pinMode(safetyPin, INPUT_PULLUP);
  if (digitalRead(safetyPin) == LOW) {
    delay(2000);
You will have to connect A0 to GND to send data; disconnect from GND if you want to stop it.
If you start experimenting with HIDs, I advise you to use something like below; you would not be the first one that manages to spam the PC with keypresses (and forgets to release the key) and text. It's an extension of the above.
#define SAFETY_ENABLED HIGH
const uint8_t safetyPin = A1;
  while (!Serial);
  static bool isPressed = false;
  // check if the safetyPin is connected to ground
  if (digitalRead(safetyPin) != SAFETY_ENABLED)
    // do your stuff here
  // if the safety pin is not connected to ground
    // release any key that might be stuck
    Keyboard.releaseAll();
It was an awkward question because it was a translation machine, but thank you for answering.
I think HID needs to study more. I connected A0 and GND in the first way, so I did the desired action well. It's strange, but after a day, I retried the code I asked and it worked. I feel like I'm being played by Arduino :slight_smile:
