keyboard.h won't print @ character
Hi
So I'm running a pro micro but cant get it to press/print or write the @ symbol using the keyboard.h lib to send the character to my PC.
tried using alt + 64 before someone suggests that.
so 63 works output is ?
and 65 works output is A
but 64 gives me "
tried using both the Dec value and '@' symbol
any ideas ?
is this not a printable character ?
Thanks Ian
What is the keyboard language on the PC?
If it’s not a standard QWERTY keyboard then you’ll have such issues.
Read this article for more details (use an online translator if you don’t read french)
I'm Assuming you're using a UK layout, On a US layout Shift-2 = @ and on a UK layout Shift-2 = "
So your issue kinda makes sense ( if you are indeed using a UK layout).
try this...
Keyboard.press( KEY_RIGHT_SHIFT);
    Keyboard.write(39);
    Keyboard.release( KEY_RIGHT_SHIFT);
Thanks B-D-N that's spot on karma added.
Can I ask where you referenced that from as most of the values on http://www.asciitable.com/ work fine .
But there has been a few that don't match up.
Thanks Ian.
You're welcome Ian,
I should have explained myself earlier.
Once I realised Shift + 2 and Alt + 64 give the same result it dawned on me we could just use Shift + apostrophe to get the @ symbol ( on a UK keyboard ) and the code for apostrophe turned out to be 39.
if you google translate the link I gave you in the first answer, you'll have more details and code you can adjust to deal with other characters that could pose problems.
I took a quick look J-M-L at that post I've added it to shortcuts to read later.
Although I can see in the code that it shows the same thing.
I really need to sit down and go through at least the US and UK keyboard differences when I have time.
Thanks for your help
