Hey Guys, I am currently trying to get the keyboard to control the paddles in Pong, - however what ever I try it stops displaying the paddles on the Matrix. The code I am using was done for two matrix displays which I have now changed to one and the code was also using analogs to make the paddles move. See below:
8x8 LED matrix pong
for Arduino Mega
This example controls two 8x8 LED matrices in a game of pong.
It takes input from two analog inputs to set the
paddles, and moves the ball accordingly.
created 1 Apr 2009
by Tom Igoe
The matrices used are labeled HS-788AS. They were bought surplus.
They are laid out as follows
(warning: yours might have different pin configurations):
rows are the anodes
cols are the cathodes
label HS-788AS is on the left side of the chip
_________
col 4 ----| |---- row 1
col 2 ----| |---- row 2
row 7 ----| |---- col 7
row 6 ----| |---- row 8
col 1 ----| |---- col 5
row 4 ----| |---- row 3
col 3 ----| |---- row 5
col 6 ----| |---- col 8
Pin numbers:
Matrix 1:
2,3,4,5,6,7,8,9,12,11,12,13, 34, 35, 36, 37
Matrix 2:
22,23,24,25,26,27,28,29,30,31,38,39,41,43,45,47,49,51,53
// define the edges of the screen:
#define LEFT 0
#define RIGHT 7
#define TOP 0
#define BOTTOM 7
int pixels[8][8]; // 2-dimensional array of pixels
// 2-dimensional array of row pin numbers (for two matrices):
[glow]int row[1][8] = {
11,14,16,3,13,5,7,9 // As You can see modified to one
// 2-dimensional array of column pin numbers (for two matrices):
int col[1][8] = {
8,6,4,2,17,15,12,10 // As You can see modified to one
};[/glow]
int ballX = 6; // X position of the ball
int ballY = 6; // Y position of the ball
int ballDirectionY = 1; // X direction of the ball
int ballDirectionX = 1; // Y direction of the ball
int rightPaddleY = 0; // X position of the center of the right paddle
int leftPaddleY = 0; // Y position of the center of the right paddle
long timeStamp = 0; // time stamp to control the pauses between ball moves
long interval = 120; // interval between ball moves, in milliseconds
boolean gamePaused = false; // state of the game
#include <ps2.h>
PS2 kbd(19, 18);
void kbd_init()
char ack;
kbd.write(0xff); // send reset code
ack = kbd.read(); // byte, kbd does self test
ack = kbd.read(); // another ack when self test is done
// initialize the I/O pins as outputs:
// iterate over the two matrices:
for (int thisMatrix = 0; thisMatrix < 1; thisMatrix++) {
// iterate over the pins:
for (int thisPin = 0; thisPin < 8; thisPin++) {
// initialize the output pins:
pinMode(col[thisMatrix][thisPin], OUTPUT);
pinMode(row[thisMatrix][thisPin], OUTPUT);
// take the col pins (i.e. the cathodes) high to ensure that
// the LEDS are off:
digitalWrite(col[thisMatrix][thisPin], HIGH);
// initialize the pixel matrix:
for (int x = 0; x < 8; x++) {
for (int y = 0; y < 8; y++) {
pixels[x][y] = HIGH;
// read input:
readSensors();
// move the ball:
if (gamePaused) {
if (millis() - timeStamp > interval*10) {
// if enough time has passed, start the game again:
gamePaused = false;
// if the game isn't paused, and enough time between ball moves
// has passed, move the ball and update the timestamp:
else {
if (millis() - timeStamp > interval) {
moveBall();
timeStamp = millis();
// draw the screen:
refreshScreen();
void readSensors() {
// set the left paddle to off:
setPaddle(LEFT, leftPaddleY, HIGH);
// set the right paddle to off:
setPaddle(RIGHT, rightPaddleY, HIGH);
// read the sensors for X and Y values:
[glow] if (keyPressed) {
keyRead();
}[/glow]
// set the left paddle to on:
setPaddle(LEFT, leftPaddleY, LOW);
// set the right paddle to on:
setPaddle(RIGHT, rightPaddleY, LOW);
void setPaddle(int paddleX, int paddleY, int state) {
// set the last right paddle to on:
pixels[paddleX][paddleY] = state;
// set the bottom pixel of the paddle:
if (paddleY < BOTTOM) {
pixels[paddleX][paddleY+1] = state;
// set the top pixel of the paddle:
if (paddleY > TOP) {
pixels[paddleX][paddleY-1] = state;
void moveBall() {
// check to see if the ball is in the horizontal range
// of the paddles:
// right:
if (ballX >= RIGHT - 1) {
// if the ball's next Y position is between
// the top and bottom of the paddle, reverse its X direction:
if ((ballY + ballDirectionY >= rightPaddleY - 1)
&& (ballY + ballDirectionY <= rightPaddleY +1)) {
// reverse the ball horizontal direction:
ballDirectionX = -ballDirectionX;
// left:
if (ballX <= LEFT + 1) {
if ((ballY + ballDirectionY >= leftPaddleY -1 )
&& (ballY + ballDirectionY <= leftPaddleY +1 )) {
// if the ball goes off the screen bottom,
// reverse its Y direction:
if (ballY == BOTTOM) {
ballDirectionY = -ballDirectionY;
// if the ball goes off the screen top,
// reverse its X direction:
if (ballY == TOP) {
// clear the ball's previous position:
pixels[ballX][ballY] = HIGH;
// if the ball goes off the screen left or right:
if ((ballX == LEFT) || (ballX == RIGHT)) {
// reset the ball:
ballX = 3;
ballY = 4;
// pause and note the time you paused:
gamePaused = true;
// increment the ball's position in both directions:
ballX = ballX + ballDirectionX;
ballY = ballY + ballDirectionY;
// if the game isn't paused, set the ball
// in its new position:
if (!gamePaused) {
// set the new position:
pixels[ballX][ballY] = LOW;
void refreshScreen() {
// iterate over the matrices:
// iterate over the rows (anodes):
for (int thisRow = 0; thisRow < 8; thisRow++) {
// take the row pin (anode) high:
digitalWrite(row[thisMatrix][thisRow], HIGH);
// iterate over the cols (cathodes):
for (int thisCol = 0; thisCol < 8; thisCol++) {
// get the state of the current pixel;
int thisPixel = pixels[thisRow+ (thisMatrix * 8)][thisCol];
// when the row is HIGH and the col is LOW,
// the LED where they meet turns on:
digitalWrite(col[thisMatrix][thisCol], thisPixel);
// turn the pixel off:
digitalWrite(col[thisMatrix][thisCol], HIGH);
// take the row pin low to turn off the whole row:
digitalWrite(row[thisMatrix][thisRow], LOW);
void keyRead() {
byte result = ps2Keyboard_CharBuffer;
switch (result) {
case 0x4B: // right down
if (leftPaddleY < BOTTOM) {
leftPaddleY++;
case 0x44 // right up
if (leftPaddleY > TOP) {
leftPaddleY--;
case 0x1B: // left down
if (rightPaddleY < BOTTOM) {
rightPaddleY++;
case 0x1D: // left up
if (rightPaddleY > TOP) {
rightPaddleY--;
Here you, can see what I have changed. I am just not sure what I should be putting in key Pressed. I am also having trouble with the brightness of the Matrix display, if anyone can see a solution to make it brighter - this would also help thanks
