keyboard.press all keys from one input ?
Hi , thanks for the help in the end I noticed I was getting a slightly higher value from which ever pin was meant to be activating and this solved it
#include <MovingAvarageFilter.h>
MovingAvarageFilter movingAvarageFilter1(20);
MovingAvarageFilter movingAvarageFilter2(20);
MovingAvarageFilter movingAvarageFilter3(20);
MovingAvarageFilter movingAvarageFilter4(20);
MovingAvarageFilter movingAvarageFilter5(20);
MovingAvarageFilter movingAvarageFilter6(20);
boolean check1 = false;
boolean check2 = false;
boolean check3 = false;
boolean check4 = false;
boolean check5 = false;
boolean check6 = false;
  analogRead(0);
  analogRead(0);
  float output1 = movingAvarageFilter1.process(analogRead(0));
  analogRead(1);
  analogRead(1);
  float output2 = movingAvarageFilter2.process(analogRead(1));
  analogRead(2);
  analogRead(2);
  float output3 = movingAvarageFilter3.process(analogRead(2));
  analogRead(3);
  analogRead(3);
  float output4 = movingAvarageFilter4.process(analogRead(3));
  analogRead(4);
  analogRead(4);
  float output5 = movingAvarageFilter5.process(analogRead(4));
  analogRead(5);
  analogRead(5);
  float output6 = movingAvarageFilter6.process(analogRead(5));
  if (output1 >= 750 && output1 <= 800)  {   // you can change this parameter to fine tune the sensitivity
    if (!check1){
      Keyboard.press(KEY_CAPS_LOCK);
      Keyboard.press ('d');
      Serial.println(output1);
      check1 = !check1;
  if (output1 >1000) {
    if (check1){
      Keyboard.release ('d');
      check1 = !check1;
  if (output2 >= 750 && output2 <= 800) {   // you can change this parameter to fine tune the sensitivity
    if (!check2){
      Keyboard.press('s');
      Serial.println(output2);
      check2 = !check2;
  if (output2 >1000) {
    if (check2){
      Keyboard.release ('s');
      check2 = !check2;
  if (output3 >= 750 && output3 <= 800) {   // you can change this parameter to fine tune the sensitivity
    if (!check3){
      Keyboard.press('f');
      Serial.println(output3);
      check3 = !check3;
  if (output3 >1000) {
    if (check3){
      Keyboard.release ('f');
      check3 = !check3;
  if (output4 >= 750 && output3 <= 800) {   // you can change this parameter to fine tune the sensitivity
    if (!check4){
      Keyboard.press('g');
      Serial.println(output4);
      check4 = !check4;
  if (output4 >1000) {
    if (check4){
      Keyboard.release ('g');
      check4 = !check4;
  if (output5 >= 750 && output5 <= 800) {   // you can change this parameter to fine tune the sensitivity
    if (!check5){
      Keyboard.press('h');
      Serial.println(output5);
      check5 = !check5;
  if (output5 >1000) {
    if (check5){
      Keyboard.release ('h');
      check5 = !check5;
  if (output6 >= 750 && output6 <= 800) {   // you can change this parameter to fine tune the sensitivity
    if (!check6){
      Keyboard.press('j');
      Serial.println(output6);
      check6 = !check6;
  if (output6 >1000) {
    if (check6){
      Keyboard.release ('j');
      check6 = !check6;
