I have a toggle switch and when it's flicked down, I want it to press '/' and when it's up, I want it to press '#' for example. This is the relevant section of code.
switchState_13 = digitalRead(SwitchPin_13);
delay(50); // contact debounce
if (switchState_13 != lastswitchState_13){
Keyboard.press(pin_input_13);
delay(50);
Keyboard.release(pin_input_13);
But when I include an "If" or "else" statement, it presses rapidly. Any ideas? Thanks
Post all of your code. For example, where is lastswitchState_13 set?
Also, what type of switch is it? Does it remain open when toggled?
jAMDup
July 7, 2015, 10:09am
3
Here's the code, sorry it's messy. This is the switch And what do you mean by "open?" Thanks.
///////////// Pin 1 ////////////////////
int switchState_1 = 0;
int lastswitchState_1 = 0;
int SwitchPin_1 = 1;
char pin_input_1 = '1';
///////////// Pin 2 ////////////////////
int switchState_2 = 0;
int lastswitchState_2 = 0;
int SwitchPin_2 = 2;
char pin_input_2 = 'A';
///////////// Pin 3 ////////////////////
int switchState_3 = 0;
int lastswitchState_3 = 0;
int SwitchPin_3 = 3;
char pin_input_3 = 'B';
///////////// Pin 4 ////////////////////
int switchState_4 = 0;
int lastswitchState_4 = 0;
int SwitchPin_4 = 4;
char pin_input_4 = 'C';
///////////// Pin 5 ////////////////////
int switchState_5 = 0;
int lastswitchState_5 = 0;
int SwitchPin_5 = 5;
char pin_input_5 = 'D';
///////////// Pin 6 ////////////////////
int switchState_6 = 0;
int lastswitchState_6 = 0;
int SwitchPin_6 = 6;
char pin_input_6 = 'E';
///////////// Pin 7 ////////////////////
int switchState_7 = 0;
int lastswitchState_7 = 0;
int SwitchPin_7 = 7;
char pin_input_7 = 'F';
///////////// Pin 8 ////////////////////
int switchState_8 = 0;
int lastswitchState_8 = 0;
int SwitchPin_8 = 8;
char pin_input_8 = 'i';
///////////// Pin 9 ////////////////////
int switchState_9 = 0;
int lastswitchState_9 = 0;
int SwitchPin_9 = 9;
char pin_input_9 = '2';
///////////// Pin 10 ////////////////////
int switchState_10 = 0;
int lastswitchState_10 = 0;
int SwitchPin_10 = 10;
char pin_input_10 = KEY_HOME;
///////////// Pin 11 ////////////////////
int switchState_11 = 0;
int lastswitchState_11 = 0;
int SwitchPin_11 = 11;
char pin_input_11 = '/';
///////////// Pin 12 ////////////////////
int switchState_12 = 0;
int lastswitchState_12 = 0;
int SwitchPin_12 = 12;
char pin_input_12 = ';';
///////////// Pin 13 ////////////////////
int switchState_13 = 0;
int lastswitchState_13 = 0;
int SwitchPin_13 = 13;
char pin_input_13 = 'w';
char pin_input_13_2 = 'W';
//int switchState = 0;
//int lastswitchState = 0;
pinMode(SwitchPin_1,INPUT_PULLUP);
pinMode(SwitchPin_2,INPUT_PULLUP);
pinMode(SwitchPin_3,INPUT_PULLUP);
pinMode(SwitchPin_4,INPUT_PULLUP);
pinMode(SwitchPin_5,INPUT_PULLUP);
pinMode(SwitchPin_6,INPUT_PULLUP);
pinMode(SwitchPin_7,INPUT_PULLUP);
pinMode(SwitchPin_8,INPUT_PULLUP);
pinMode(SwitchPin_9,INPUT_PULLUP);
pinMode(SwitchPin_10,INPUT_PULLUP);
pinMode(SwitchPin_11,INPUT_PULLUP);
pinMode(SwitchPin_12,INPUT_PULLUP);
pinMode(SwitchPin_13,INPUT_PULLUP);
Keyboard.begin();
////////////////////// Pin 1 /////////////////////
switchState_1 = digitalRead(SwitchPin_1);
if (switchState_1 != lastswitchState_1){
Keyboard.print(pin_input_1);
lastswitchState_1 = switchState_1;
////////////////////// Pin 2 /////////////////////
switchState_2 = digitalRead(SwitchPin_2);
if (switchState_2 != lastswitchState_2){
Keyboard.print(pin_input_2);
lastswitchState_2 = switchState_2;
////////////////////// Pin 3 /////////////////////
switchState_3 = digitalRead(SwitchPin_3);
if (switchState_3 != lastswitchState_3){
Keyboard.print(pin_input_3);
lastswitchState_3 = switchState_3;
////////////////////// Pin 4 /////////////////////
switchState_4 = digitalRead(SwitchPin_4);
if (switchState_4 != lastswitchState_4){
Keyboard.print(pin_input_4);
lastswitchState_4 = switchState_4;
////////////////////// Pin 5 /////////////////////
switchState_5 = digitalRead(SwitchPin_5);
if (switchState_5 != lastswitchState_5){
Keyboard.print(pin_input_5);
lastswitchState_5 = switchState_5;
////////////////////// Pin 6 /////////////////////
switchState_6 = digitalRead(SwitchPin_6);
if (switchState_6 != lastswitchState_6){
Keyboard.print(pin_input_6);
lastswitchState_6 = switchState_6;
/////////////WWWWWWW///////// Pin 7 /////////////////////
switchState_7 = digitalRead(SwitchPin_7);
if (switchState_7 != lastswitchState_7){
Keyboard.print(pin_input_7);
lastswitchState_7 = switchState_7;
////////////////////// Pin 8 /////////////////////
switchState_8 = digitalRead(SwitchPin_8);
if (switchState_8 != lastswitchState_8){
Keyboard.print(pin_input_8);
lastswitchState_8 = switchState_8;
////////////////////// Pin 9 /////////////////////
switchState_9 = digitalRead(SwitchPin_9);
if (switchState_9 != lastswitchState_9){
Keyboard.print(pin_input_9);
lastswitchState_9 = switchState_9;
////////////////////// Pin 10 /////////////////////
switchState_10 = digitalRead(SwitchPin_10);
if (switchState_10 != lastswitchState_10){
Keyboard.print(pin_input_10);
lastswitchState_10 = switchState_10;
////////////////////// Pin 11 /////////////////////
switchState_11 = digitalRead(SwitchPin_11);
if (switchState_11 != lastswitchState_11){
Keyboard.print(pin_input_11);
lastswitchState_11 = switchState_11;
////////////////////// Pin 12 /////////////////////
switchState_12 = digitalRead(SwitchPin_12);
if (switchState_12 != lastswitchState_12){
Keyboard.press(pin_input_12);
delay(10);
Keyboard.release(pin_input_12);
lastswitchState_12 = switchState_12;
////////////////////// Pin 13 /////////////////////
delay(50);
lastswitchState_13 = switchState_13;
ok try this, haven't tested it:
bool g_toggle = false;// put this line with your globals
g_toggle != g_toggle;
char input = '#';
if( g_toggle )
input = '/';
Keyboard.press(input);
delay(50);
Keyboard.release(input);
jAMDup
July 7, 2015, 10:49am
5
It doesn't work, it outputs "#" both times.
Yea my bad, that'll teach me to read it before I post.
change this line:
to this:
g_toggle = !g_toggle;
jAMDup
July 7, 2015, 11:03am
7
Haha don't worry, it works now, thank you so much.
