Hi, i am new to arduino project and currently want to create a project of 'automatically lock the windows when the seat occupancy is zero' based on OMRON thermal array.
So the idea is to lock the windows when the omron thermal array is not sensing the presence of a person in front of the computer.
Currently i am using Arduino MKR wifi 1010 and i am using the code from seat occupancy project,
I modified the code by adding method lockScreen() that will be accessed whenever the seat occupancy result is 0.
/* includes */
#include <Wire.h>
#include <Keyboard.h>
/* defines */
#define D6T_ADDR 0x0A // for I2C 7bit address
#define D6T_CMD 0x4C // for D6T-44L-06/06H, D6T-8L-09/09H, for D6T-1A-01/02
#define N_ROW 16
#define N_PIXEL (4 * 4)
#define N_READ ((N_PIXEL + 1) * 2 + 1)
#define SAMPLE_TIME_0045MS 45
#define SAMPLE_TIME_0090MS 90
#define SAMPLE_TIME_0130MS 130
#define SAMPLE_TIME_0175MS 175
#define SAMPLE_TIME_0215MS 215
#define SAMPLE_TIME_0260MS 260
#define SAMPLE_TIME_0300MS 300
#define SAMPLE_TIME_0345MS 345
#define SAMPLE_TIME_0390MS 390
#define SAMPLE_TIME_0430MS 430
#define SAMPLE_TIME_0475MS 475
#define SAMPLE_TIME_0515MS 515
#define SAMPLE_TIME_0560MS 560
#define SAMPLE_TIME_0600MS 600
#define SAMPLE_TIME_0645MS 645
#define SAMPLE_TIME_0690MS 690
#define SAMPLE_TIME_0730MS 730
#define SAMPLE_TIME_0775MS 775
#define SAMPLE_TIME_0815MS 815
#define SAMPLE_TIME_0860MS 860
#define SAMPLE_TIME_0900MS 900
#define SAMPLE_TIME_0945MS 945
#define SAMPLE_TIME_0990MS 990
#define SAMPLE_TIME_1030MS 1030
#define SAMPLE_TIME_1070MS 1070
#define SAMPLE_TIME_1115MS 1115
#define SAMPLE_TIME_1160MS 1160
#define SAMPLE_TIME_1200MS 1200
#define SAMPLE_TIME_1245MS 1245
#define SAMPLE_TIME_1290MS 1290
#define SAMPLE_TIME_1330MS 1330
#define SAMPLE_TIME_1370MS 1370
#define PARA_0045MS ((uint8_t)0x01)
#define PARA_0090MS ((uint8_t)0x02)
#define PARA_0130MS ((uint8_t)0x03)
#define PARA_0175MS ((uint8_t)0x04)
#define PARA_0215MS ((uint8_t)0x05)
#define PARA_0260MS ((uint8_t)0x06)
#define PARA_0300MS ((uint8_t)0x07)
#define PARA_0345MS ((uint8_t)0x08)
#define PARA_0390MS ((uint8_t)0x09)
#define PARA_0430MS ((uint8_t)0x0A)
#define PARA_0475MS ((uint8_t)0x0B)
#define PARA_0515MS ((uint8_t)0x0C)
#define PARA_0560MS ((uint8_t)0x0D)
#define PARA_0600MS ((uint8_t)0x0E)
#define PARA_0645MS ((uint8_t)0x0F)
#define PARA_0690MS ((uint8_t)0x10)
#define PARA_0730MS ((uint8_t)0x11)
#define PARA_0775MS ((uint8_t)0x12)
#define PARA_0815MS ((uint8_t)0x13)
#define PARA_0860MS ((uint8_t)0x14)
#define PARA_0900MS ((uint8_t)0x15)
#define PARA_0945MS ((uint8_t)0x16)
#define PARA_0990MS ((uint8_t)0x17)
#define PARA_1030MS ((uint8_t)0x18)
#define PARA_1070MS ((uint8_t)0x19)
#define PARA_1115MS ((uint8_t)0x1A)
#define PARA_1160MS ((uint8_t)0x1B)
#define PARA_1200MS ((uint8_t)0x1C)
#define PARA_1245MS ((uint8_t)0x1D)
#define PARA_1290MS ((uint8_t)0x1E)
#define PARA_1330MS ((uint8_t)0x1F)
#define PARA_1370MS ((uint8_t)0x20)
/***** Setting Parameter *****/
#define comparingNumInc 5 // x300 ms (range: 1 to 39) (example) 5 -> 1.5 sec
#define comparingNumDec 5 // x300 ms (range: 1 to 39) (example) 5 -> 1.5 sec
#define threshHoldInc 10 // /10 degC (example) 10 -> 1.0 degC
#define threshHoldDec 10 // /10 degC (example) 10 -> 1.0 degC
bool enablePix[16] = {true, true, true, true, true, true, true, true, true, true, true, true, true, true, true, true};
/***** Setting Parameter 2 *****/
#define samplingTime SAMPLE_TIME_0300MS //ms (Can select only, 45ms, 90ms, 130ms, 175ms, 215ms, 260ms, 300ms, 435ms, 390ms, 430ms, 475ms, 515ms, 560ms, 600ms, 645ms, 690ms, 730ms, 775ms, 815ms, 860ms, 900ms, 945ms, 990ms, 1030ms, 1070ms, 1115ms, 1160ms, 1200ms, 1245ms, 1290ms, 1330ms, 1370ms)
uint8_t rbuf[N_READ];
int16_t pix_data[16] = {0};
int16_t seqData[16][40] = {0};
bool occuPix[16] = {0};
bool occuPixFlag = false;
uint8_t resultOccupancy = 0;
uint16_t totalCount = 0;
/** JUDGE_occupancy: judge occupancy*/
bool judge_seatOccupancy(void) {
int i = 0;
int j = 0;
for (i = 0; i < 16; i++) {
for (j = 0; j < 39; j++) {
seqData[i][39 - j] = seqData[i][38 - j];
seqData[i][0] = pix_data[i];
if (totalCount <= comparingNumInc) {
totalCount++;
if (totalCount > comparingNumInc) {
if (enablePix[i] == true) {
if (occuPix[i] == false) {
if ((int16_t)(seqData[i][0] - seqData[i][comparingNumInc]) >= (int16_t)threshHoldInc) {
occuPix[i] = true;
else {
if ((int16_t)(seqData[i][comparingNumDec] - seqData[i][0]) >= (int16_t)threshHoldDec) {
occuPix[i] = false;
if (resultOccupancy == 0) {
if (occuPix[i] == true) {
resultOccupancy = 1;
else { //resultOccupancy == true
occuPixFlag = true;
else {
if (occuPixFlag == false) {
return true;
uint8_t calc_crc(uint8_t data) {
int index;
uint8_t temp;
for (index = 0; index < 8; index++) {
temp = data;
data <<= 1;
if (temp & 0x80) {
data ^= 0x07;
return data;
/** <!-- D6T_checkPEC {{{ 1--> D6T PEC(Packet Error Check) calculation.
calculate the data sequence,
from an I2C Read client address (8bit) to thermal data end.
bool D6T_checkPEC(uint8_t buf[], int n) {
int i;
uint8_t crc = calc_crc((D6T_ADDR << 1) | 1); // I2C Read address (8bit)
for (i = 0; i < n; i++) {
crc = calc_crc(buf[i] ^ crc);
bool ret = crc != buf[n];
if (ret) {
Serial.print("PEC check failed:");
Serial.print(crc, HEX);
Serial.print("(cal) vs ");
Serial.print(buf[n], HEX);
Serial.println("(get)");
return ret;
/** <!-- conv8us_s16_le {{{1 --> convert a 16bit data from the byte stream.
int16_t conv8us_s16_le(uint8_t* buf, int n) {
int ret;
ret = buf[n];
ret += buf[n + 1] << 8;
return (int16_t)ret; // and convert negative.
/** <!-- setup {{{1 -->
1. initialize a Serial port for output.
2. initialize an I2C peripheral.
uint8_t para = 0;
switch (samplingTime) {
case SAMPLE_TIME_0045MS:
para = PARA_0045MS;
case SAMPLE_TIME_0090MS:
para = PARA_0090MS;
case SAMPLE_TIME_0130MS:
para = PARA_0130MS;
case SAMPLE_TIME_0175MS:
para = PARA_0175MS;
case SAMPLE_TIME_0215MS:
para = PARA_0215MS;
case SAMPLE_TIME_0260MS:
para = PARA_0260MS;
case SAMPLE_TIME_0300MS:
para = PARA_0300MS;
case SAMPLE_TIME_0345MS:
para = PARA_0345MS;
case SAMPLE_TIME_0390MS:
para = PARA_0390MS;
case SAMPLE_TIME_0430MS:
para = PARA_0430MS;
case SAMPLE_TIME_0475MS:
para = PARA_0475MS;
case SAMPLE_TIME_0515MS:
para = PARA_0515MS;
case SAMPLE_TIME_0560MS:
para = PARA_0560MS;
case SAMPLE_TIME_0600MS:
para = PARA_0600MS;
case SAMPLE_TIME_0645MS:
para = PARA_0645MS;
case SAMPLE_TIME_0690MS:
para = PARA_0690MS;
case SAMPLE_TIME_0730MS:
para = PARA_0730MS;
case SAMPLE_TIME_0775MS:
para = PARA_0775MS;
case SAMPLE_TIME_0815MS:
para = PARA_0815MS;
case SAMPLE_TIME_0860MS:
para = PARA_0860MS;
case SAMPLE_TIME_0900MS:
para = PARA_0900MS;
case SAMPLE_TIME_0945MS:
para = PARA_0945MS;
case SAMPLE_TIME_0990MS:
para = PARA_0990MS;
case SAMPLE_TIME_1030MS:
para = PARA_1030MS;
case SAMPLE_TIME_1070MS:
para = PARA_1070MS;
case SAMPLE_TIME_1115MS:
para = PARA_1115MS;
case SAMPLE_TIME_1160MS:
para = PARA_1160MS;
case SAMPLE_TIME_1200MS:
para = PARA_1200MS;
case SAMPLE_TIME_1245MS:
para = PARA_0945MS;
case SAMPLE_TIME_1290MS:
para = PARA_1290MS;
case SAMPLE_TIME_1330MS:
para = PARA_1330MS;
case SAMPLE_TIME_1370MS:
para = PARA_1370MS;
default:
para = PARA_0300MS;
Serial.begin(115200); // Serial baudrate = 115200bps
Wire.begin(); // i2c master
Wire.beginTransmission(D6T_ADDR); // I2C client address
Wire.write(0x50); // D6T register
Wire.write(0x52); // D6T register
Wire.write(0x45); // D6T register
Wire.write(0x4C); // D6T register
Wire.write(0x41); // D6T register
Wire.write(0x53); // D6T register
Wire.write(0x00); // D6T register
Wire.endTransmission(); // I2C repeated start for read
Wire.write(0x42); // D6T register
Wire.write(para); // D6T register
Keyboard.begin(); //begin control over keyboard
/** <!-- loop - Thermal sensor {{{1 -->
1. read sensor.
2. output results, format is: [degC]
int i, j;
int jj;
memset(rbuf, 0, N_READ);
// Wire buffers are enough to read D6T-16L data (33bytes) with
// MKR-WiFi1010 and Feather ESP32,
// these have 256 and 128 buffers in their libraries.
Wire.write(D6T_CMD); // D6T register
delay(1);
Wire.requestFrom(D6T_ADDR, N_READ);
i = 0;
while (Wire.available()) {
rbuf[i++] = Wire.read();
if (D6T_checkPEC(rbuf, N_READ - 1)) {
return;
// 1st data is PTAT measurement (: Proportional To Absolute Temperature)
int16_t itemp = conv8us_s16_le(rbuf, 0);
Serial.print("PTAT:");
Serial.print(itemp / 10.0, 1);
Serial.print(", Temperature:");
// loop temperature pixels of each thrmopiles measurements
for (i = 0, j = 2; i < N_PIXEL; i++, j += 2) {
itemp = conv8us_s16_le(rbuf, j);
pix_data[i] = itemp;
Serial.print(itemp / 10.0, 1); // print PTAT & Temperature
/**********debug ***********************/
//Serial.print(",");
//if(occuPix[i] == false){
// jj = 0;
//else{
// jj = 1;
//Serial.print(jj, 1);
if ((i % N_ROW) == N_ROW - 1) {
Serial.print(" [degC]"); // wrap text at ROW end.
Serial.print(", "); // print delimiter
judge_seatOccupancy(); //add
Serial.print(", Occupancy:");
Serial.println(resultOccupancy, 1);
//lock windows if no person is detected
lockScreen();
delay(samplingTime);
// vi: ft=arduino:fdm=marker:et:sw=4:tw=80
void lockScreen() {
Keyboard.begin();
Serial.println("pressing");
Keyboard.press(KEY_LEFT_GUI);
Keyboard.press('l');
Keyboard.releaseAll();
delay(5000);
But whenever the seat occupancy equals to 0, it didn't automatically lock the windows.
Please if there's someone who might know the issue, kindly help me. If you need other info regarding to the code/hardware or software that I'm using, just ask.
Thank you!
