Keyboard question
OK I think i figured out how to control a relay via a laptop keyboard
my question is there a list of keys some place like example “if(incomingbyte == 98){”
98 that’s the b key, what are the others?.
int incomingbyte;
pinMode(7, OUTPUT);
digitalWrite(7, HIGH);
if (Serial.available() > 0) {
incomingbyte = Serial.read();
digitalWrite(7, LOW);
I think you need the ASCII table http://www.asciitable.com/
oh wow tnx
ASCII characters with SINGLE quotes (apostrophes) around them translate into the correct numbers.
/*There are all True*/
'b' == 98;
' ' == 32;
'A' == 65;
New problem, seems like it all works, but every time I open the Terminal to enter in the key my relay shuts off for like a second as it connects to the port. Here’s my program
  //  Some macros for defining time intervals in milliseconds
#define seconds_in_ms(s) ((s)*1000UL)
#define minutes_in_ms(m) ((m)*60UL*1000UL)
#define hours_in_ms(h)   ((h)*60UL*60UL*1000UL)
#define days_in_ms(d)    ((d)*24UL*60UL*60UL*1000UL)
#define weeks_in_ms(w)   ((w)*7UL*24UL*60UL*60UL*1000UL)
unsigned long CycleStartTime = 0;
unsigned long LastTaskTime = 0;
unsigned long CurrentTaskInterval = 0;
unsigned Task = 0;
 int incomingbyte;
   pinMode(2, OUTPUT);     //PH down
   pinMode(3, OUTPUT);  //B nutrient solution
   pinMode(4, OUTPUT);  //A nutrient solution
   pinMode(5, OUTPUT);  //Drain pump
   pinMode(6, OUTPUT);   //Solenoid Valve
   pinMode(7, OUTPUT);  //Nutrient Heater
   digitalWrite(2, HIGH);     //PH down
  digitalWrite (3, HIGH);  //B nutrient solution
  digitalWrite (4, HIGH);  //A nutrient solution
  digitalWrite (5, HIGH);  //Drain pump
  digitalWrite (6, HIGH);   //Solenoid Valve
  digitalWrite(7, HIGH);  //Nutrient Heater
if(incomingbyte == 112){
digitalWrite(2, LOW);
  unsigned long currentTime = millis();
  // If the time has not yet come to perform a task
  if (currentTime - LastTaskTime < CurrentTaskInterval)
    return;   // Nothing to do
  LastTaskTime = currentTime;
  switch (Task++)
  case 0:
    CycleStartTime = currentTime;  // Remember this time
   digitalWrite(5,LOW);   // set the drain pump on
    CurrentTaskInterval = minutes_in_ms(10);
  case 1:
   digitalWrite(6, LOW); // set the Solenoid Valve on
    digitalWrite(2, LOW);  // set the PH down on
    digitalWrite(3, LOW); // set the B nutrient solution on
    digitalWrite(4, LOW); // set the A nutrient solution on
    CurrentTaskInterval = seconds_in_ms(1);
case 2:
    CurrentTaskInterval = seconds_in_ms(2);
Case 3:
CurrentTaskInterval = seconds_in_ms(7);
Case 4:
digitalWrite(7, HIGH); // set the Nutrient Heater on
// Start over again in one week from the START of the cycle
    Task = 0;
    LastTaskTime = CycleStartTime;
    CurrentTaskInterval = weeks_in_ms(1);
You're going to have to disable auto-reset -- there's a trace you can cut on the back of the board, or a very specific valued resistor can go somewhere (google it).
Thanks I’m going to try the resistor capacitor thing what a pain.
I tweaked my sketch a little and now it wont load, I cant see where I went wrong.
a lil help would be really nice
Thanks you guys are the best
unsigned Task = 0;
 int incomingbyte;
   digitalWrite(2, HIGH); //PH down off
  digitalWrite(3, HIGH);  //B nutrient solution off
  digitalWrite(4, HIGH);  //A nutrient solution off
  digitalWrite(5, HIGH);  //Drain pump off
  digitalWrite(6, HIGH);   //Solenoid Valve off
  digitalWrite(7, HIGH);  //Nutrient Heater off
if(incomingbyte == 110){
digitalWrite(4,LOW);
digitalWrite(4,HIGH);
  switch (Task++)
  case 0:
  case 1:
case 2:
case 3:
case 4:
    Task = 0;
If you've disabled auto-reset, you'll have to manually reset to upload.
No I haven’t disabled the reset yet, I need to buy some parts, my problem is with the program now. IDE doesn’t like it,
Ive got errors after tweaking it a bit. where did I go wrong?
tnx
It won't load if it doesn't compile.
That’s what I mean, I tweaked it, and screwed up something, it wont compile.
here’s what I have so far, where did I go wrong?.
unsigned Task = 0;
 int incomingbyte;
  switch (Task++)
  case 0:
  case 1:
case 2:
case 3:
case 4:
    Task = 0;
right there.
That's what I mean, I tweaked it, and screwed up something, it wont compile
compile != load
