Keyboard.write problem.
Hello, I'm working on a project with arduino leonardo, which sent a sentence trougth the serial port and get an int variable that I use in "keyboard.write" for example "Keyboard.write (125)," In theory according to table would have to print the ascii character "}" but prints "*". but works well with letters, numbers and the "modifier keystrokes" Any idea what could be happening?
Here is some code:
while (Serial.available()) //Sumo uno tras otro los caracteres seriales y creo una string.
    delay(3);  //delay to allow buffer to fill
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if(readString.startsWith("KW")) //KwyWrite, preciona una tecla y la suelta inmediatamente.  ejemplo KW065 o KP65
    String KeyStrokevalue = readString.substring(2, readString.length()); //Obtengo el valor del KeyStroke
    Serial.println(KeyStrokevalue.toInt());
    Keyboard.write(KeyStrokevalue.toInt());
    readString="";
That is down to the device receiving the ASCII character, nothing to do with the Arduino sending it.
TY Mike, that is what I suspected
TYVM
