Keyestudio K0071
Hi I have a problem with my KeyeStudio Mini Tank Robot: I assembled it last night like the instructions tells
but the head, which is an HC-SR04, doesn’t move like in the videos. I think that the problem is in the code, I tried to fix it but I’m not able to find the mistake. Could you help me? I have telegram: @Creeperdanit. The code that I’m using is:
#include <Servo.h>
int pinLB = 12;     // define pin 12
int pinLF = 3;     // define pin 3
int pinRB = 13;    // define pin 13
int pinRF = 11;    // define pin 11
int inputPin = 4;    // define pin for sensor echo
int outputPin =5;    // define pin for sensor trig
int Fspeedd = 0;      // forward speed
int Rspeedd = 0;      // right speed
int Lspeedd = 0;      // left speed
int directionn = 0;   // forward=8 backward=2 left=4 right=6
Servo myservo;        // set myservo
int delay_time = 250; // settling time after steering servo motor moving B
int Fgo = 8;         // Move F
int Rgo = 6;         // move to the R
int Lgo = 4;         // move to the L
int Bgo = 2;         // move B
  Serial.begin(9600);     // Define motor output pin
  pinMode(pinLB,OUTPUT); // pin 12
  pinMode(pinLF,OUTPUT); // pin 3 (PWM)
  pinMode(pinRB,OUTPUT); // pin 13
  pinMode(pinRF,OUTPUT); // pin 11 (PWM)
  pinMode(inputPin, INPUT);    // define input pin for sensor
  pinMode(outputPin, OUTPUT);  // define output pin for sensor
  myservo.attach(9);    // Define servo motor output pin to D9 (PWM)
void advance()     // move forward
    digitalWrite(pinLB,LOW);    // right wheel moves forward
digitalWrite(pinRB, LOW);  // left wheel moves forward
    analogWrite(pinLF,255);
    analogWrite(pinRF,255);
void stopp()         // stop
     digitalWrite(pinLB,HIGH);
     digitalWrite(pinRB,HIGH);
     analogWrite(pinLF,0);
     analogWrite(pinRF,0);
void right()        // turn right (single wheel)
   digitalWrite(pinLB,HIGH);  // wheel on the left moves forward
   digitalWrite(pinRB,LOW); // wheel on the right moves backward
   analogWrite(pinLF, 255);
void left()         // turn left (single wheel)
   digitalWrite(pinLB,LOW);  // wheel on the left moves backward
   digitalWrite(pinRB,HIGH); // wheel on the right moves forward
void back()          // move backward
     digitalWrite(pinLB,HIGH);  // motor moves to left rear
     digitalWrite(pinRB,HIGH);  // motor moves to right rear
void detection()        // measure 3 angles (0.90.179)
      int delay_time = 250;   // stabilizing time for servo motor after moving backward
      ask_pin_F();            // read the distance ahead
     if(Fspeedd < 10)         // if distance ahead is <10cm
      stopp();               // clear data
      delay(100);
      back();                // move backward for 0.2S
      delay(200);
      if(Fspeedd < 25)         // if distance ahead is <25cm
        stopp();
        delay(100);             // clear data
        ask_pin_L();            // read distance on the left
        delay(delay_time);      // stabilizing time for servo motor
        ask_pin_R();            // read distance on the right
        if(Lspeedd > Rspeedd)   // if distance on the left is >distance on the right
          directionn = Lgo;      // move to the L
        if(Lspeedd <= Rspeedd)   // if distance on the left is <= distance on the right
         directionn = Rgo;      // move to the right
         if (Lspeedd < 10 && Rspeedd < 10)   // if distance on left and right are both <10cm
         directionn = Bgo;      // move backward
      else                      // if distance ahead is >25cm
        directionn = Fgo;        // move forward
void ask_pin_F()   // measure the distance ahead
      myservo.write(90);
      digitalWrite(outputPin, LOW);   // ultrasonic sensor transmit low level signal 2μs
      delayMicroseconds(2);
      digitalWrite(outputPin, HIGH);  // ultrasonic sensor transmit high level signal10μs, at least 10μs
      delayMicroseconds(10);
      digitalWrite(outputPin, LOW);    // keep transmitting low level signal
      float Fdistance = pulseIn(inputPin, HIGH);  // read the time in between
      Fdistance= Fdistance/5.8/10;       // convert time into distance (unit: cm)
      Fspeedd = Fdistance;              // read the distance into Fspeedd
 void ask_pin_L()   // measure distance on the left
      myservo.write(5);
      delay(delay_time);
      float Ldistance = pulseIn(inputPin, HIGH);  // read the time in between
      Ldistance= Ldistance/5.8/10;       // convert time into distance (unit: cm)
      Lspeedd = Ldistance;              // read the distance into Lspeedd
void ask_pin_R()   //  measure distance on the right
      myservo.write(177);
      delay(delay_time);
      float Rdistance = pulseIn(inputPin, HIGH);  // read the time in between
      Rdistance= Rdistance/5.8/10;       // convert time into distance (unit: cm)
      Rspeedd = Rdistance;              // read the distance into Rspeedd
    myservo.write(90);  // home set the servo motor, ready for next measurement
    detection();        // measure the angle and determine which direction to move
   if(directionn == 2)  // if directionn= 2
     back();
     delay(800);                    //  go backward
     left() ;
     delay(200);              // Move slightly to the left (to prevent stuck in dead end)
   if(directionn == 6)           // if directionn = 6
     back();
     delay(100);
     right();
     delay(600);                 // turn right
   if(directionn == 4)          // if directionn = 4
     back();
     delay(600);
     left();
     delay(600);                  // turn left
   if(directionn == 8)          // if directionn = 8
    advance();                 // move forward
    delay(100);
When I see those if without else that feels bad
if(Fspeedd < 10) ....
if(Fspeedd < 25) ...
because if you are less than 10 you’ll also be less than 25… is it intended?
The code is so poorly indented that it’s unreadable on my phone… press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly…
The comments are also very unhelpful to understand what you mean
if(directionn == 2)  [b]// if directionn= 2[/b][color=red] really great comment ![/color]
